Index
Quick way of finding pages based on categories and subjects.
Legalities
Basics
There's a variety of methods of repurposing these OEM components. Methods here are generally chosen with future proofing in mind , reducing chances of firmware or software updates from the manufacture "bricking" or blocking the open source control efforts. such efforts include:
- Mainboard/brain replacement
- CANBUS/LINBUS
- Sync serial
- FlexRay
- PWM
Glossary of Terms
EV conversions Parts
- Motors
- Inverter
- Batteries
- DC/DC Converters
- HV Junction Box
- Cooling System Components
- Heaters
- HVAC
- Brake Assist
- Vacuum Pumps
- Electronic Brake Boosters
- Power Steering
- Rapid Charging
- VCU Comparison
- Gear Selector
OEM Parts
- BMW
- Chevrolet
- Ford
- Hyundai
- Isabellenhütte Heusler
- Land Rover/Jaguar
- Mercedes-Benz
- MG
- Mitsubishi
- Nissan
- Opel/Vauxhall
- Peugeot
- Renault
- Tesla
- Toyota/Lexus
- Volvo
FAQ
Mechanical Design Database
Open Inverter Projects
| Description / Notes | |
| ZombieVerter VCU | Designed around a matched pair of Inverter and Motor taken from the original OEM vehicle the ZombieVerter is there to make those two components believe they are still in the original vehicle and are fed necessary commands to act as if they still are and interpret and responses back from the equipment for feedback (regen / rpm / etc) |
Open Inverter Hardware
Quite flexible in its application. The Open Inverter can be used to build a custom inverter itself where you supply the high power and high voltage components to create your own inverter, or to be used as the basis to take over control of OEM inverters so that they can drive nearly any attached motor to that inverter. |
| Open Inverter Software | Two of the more important software aspects to master are below. |
| CAN communication
| Parameters
Open Inverter Related Projects (Control Boards/VCUs)
| Project | Description / Notes |
| Tesla Small Drive and Large Drive Units: | Commonly there is a large drive unit and small drive unit available from the Model S.
| Lexus GS450h Drivetrain: | The GS450h contains a gearbox (where the motors are located).
| Prius Generation 3 Inverter: | A cheap available inverter from the popular Prius hybrid, this
board goes inside that inverter and allows you to control the features of it. |
| Auris/Yaris Inverter: | Similar to the Prius board, there's subtle differences between them
and therefore the need for a separate board. |
| Nissan Leaf Gen2 Board | Replaces the nissan OEM logic board with a rev 3 openiverter main board |
| Ford ranger ev board | openinverter kit for the ford ranger ev |
| All Control Boards / OEM Inverters | |
