Main Page Old
Revision as of 11:54, 29 March 2023 by Jason arnold (talk | contribs) (OEM Parts:: Added Land Rover/Jaguar)
The openinverter project mainly aims to reuse existing components from production electric vehicles. We also aim to give some general guidelines on how to convert a vehicle to electric drive.
Before you begin:
Please take the time to read.
The information provided on this wiki and the support forums is intended as information only. The Open Inverter project and contributors to the forums and this wiki take no responsibility for how you use the information on this site, nor any liability for injuries, or death, that may result from your actions.
www.patreon.com/openinverter,
https://www.evbmw.com/,
https://www.paypal.com/paypalme/celeron55
Welcome to the open inverter community
Legalities
Different countries have different legislation, if you want your car to certified for the road in your country please take the time to review this section. It might save you going down the wrong direction and creating something that can never be driven, or incur costs.
The open inverter started as a scratch built inverter and control board led by Johannes Hübner who designed and built his open open source AC motor controller dubbed the "open inverter".
Since then, the community has established and documented hardware and software approaches to reuse OEM inverters with the Open control board, and has more recently started on controlling OEM inverters over CAN, a process which doesn't require replacing any internal parts.
  • EV conversion
  • Energy storage
  • Power generation
  • Charging infrastructure
  • etc.
  • Motor Controllers
  • 1-3 phase power converters
  • DC/DC converters
  • buck/boost converters
  • Battery Management Systems (BMS)
  • Vehicle integration
  • etc.
such efforts include:
Getting Started
The Community is focused on the electrical systems required for an EV, and may not be best placed to assist with mechanical issues specific to your vehicle.
Glossary of Terms
EV conversions:
OEM Parts:
Required skills/Knowledge
To perform a successful EV conversion, you may require the following skills and/or knowledge (this is not an exhaustive list)
  • You will need to have the skills, knowledge and tools required to perform significant mechanical work on your vehicle. A service or workshop manual will be useful.
  • Basic DC electrical knowledge, such as using a multimeter, soldering, identifying components.
  • A willingness and ability to troubleshoot problems (mechanical, electrical, code...).
  • Safety in relation to high voltage DC systems. HV DC can be more dangerous than AC mains voltages!
  • Basic understanding on the purposes of various EV components (motor, inverter, DC-DC...)
  • A grasp of 3 phase motor control concepts can be useful (especially if using an openinverter control board)
  • An understanding of CAN (and other digital communication systems) will be very useful
  • The legal restrictions and requirements for your country/state
FAQ
Mechanical Design Database
Mechanical design database
here you will find measurements, models, files, etc for a variety of components such as:
  • adapter plates
  • motor couplers
  • drive shaft flanges
  • battery mounts
  • etc.
Open Inverter Projects
Description / Notes
ZombieVerter VCU Designed around a matched pair of Inverter and Motor taken from the original OEM vehicle the ZombieVerter is there to make those two components believe they are still in the original vehicle and are fed necessary commands to act as if they still are and interpret and responses back from the equipment for feedback (regen / rpm / etc)
Open Inverter Hardware Quite flexible in its application. The Open Inverter can be used to build a custom inverter itself where you supply the high power and high voltage components to create your own inverter, or to be used as the basis to take over control of OEM inverters so that they can drive nearly any attached motor to that inverter.
Open Inverter Software Two of the more important software aspects to master are below.
CAN communication
Parameter definitions can be found here: Parameters
Working parameter sets can be found in the openinverter parameter database
Open Inverter Related Projects (Control Boards/VCUs)
Project Description / Notes
Tesla Small Drive and Large Drive Units: Commonly there is a large drive unit and small drive unit available from the Model S.
These combine the inverter and motor into a single package.
The control boards for these replace the existing control board within them.
Lexus GS450h Drivetrain: The GS450h contains a gearbox (where the motors are located).
Using the ZombieVerter VCU, the inverter and the gearbox itself provide
a powerful set up suitable for rear wheel drive set ups, replacing the existing longitudinally mounted gearbox.
Prius Generation 3 Inverter: A cheap available inverter from the popular Prius hybrid, this
Auris/Yaris Inverter: Similar to the Prius board, there's subtle differences between them
and therefore the need for a separate board.
Nissan Leaf Gen2 Board Replaces the nissan OEM logic board with a rev 3 openiverter main board
Ford ranger ev board openinverter kit for the ford ranger ev
Open Inverter Renewables Projects
Recently added to the forums are projects and discussions around turning the Open Inverter project towards capturing, storing and using renewable energy.
Open Inverter CAN std.
Conversion Projects
