Main Page Old
Before you begin:
Please take the time to read.
The information provided on this wiki and the support forums is intended as information only. The Open Inverter project and its contributors take no responsibility for how you use the information contained within these pages, nor any liability for injuries, or death, that may result from your actions.
Consider donating to the many developers that have made all this possible and to help keep making things possible: www.patreon.com/openinverter, https://www.evbmw.com/, https://www.paypal.com/paypalme/celeron55
Welcome to the open inverter community
Legalities
Different countries have different legislation, if you want you car to certified for the road in your country please take the time to review this section. It might save you going down the wrong direction and creating something that can never be driven, or incur costs.
The open inverter project originates from Johannes Hübner designing/building his own open source AC motor controller, dubbed the "open inverter"
With the rising popularity/availability of hybrid and electric vehicles, there is a growing supply of high quality and relatively inexpensive parts from auto-wreckers.
- EV conversion
- Energy storage
- Power generation
- Charging infrastructure
- etc.
- Motor Controllers
- 1-3 phase power converters
- DC/DC converters
- buck/boost converters
- Vehicle integration
- etc.
such efforts include:
- Mainboard/brain replacement
- CANBUS/LINBUS
- Sync serial
- FlexRay
- PWM
- etc.
Getting Started
Glossary of Terms
EV conversions:
- Motors
- Inverter
- Batteries
- DC/DC Converters
- HV Junction Box
- Heaters
- HVAC
- Brake Assist
- Vacuum Pumps
- Electronic Brake Boosters
- Power Steering
- Rapid Charging
OEM Parts:
- BMW
- Chevrolet
- Ford
- Hyundai
- Isabellenhütte Heusler
- Mercedes-Benz
- Mitsubishi
- Nissan
- Opel/Vauxhall
- Tesla
- Toyota/Lexus
- Volvo
FAQ
mechanical design database
here you will find measurements, models, files, etc for a variety of components such as:
- adapter plates
- motor couplers
- drive shaft flanges
- battery mounts
- etc.
Open Inverter Projects
| Description / Notes | |
| ZombieVerter VCU | Designed around a matched pair of Inverter and Motor taken from the original OEM vehicle the ZombieVerter is there to make those two components believe they are still in the original vehicle and are fed necessary commands to act as if they still are and interpret and responses back from the equipment for feedback (regen / rpm / etc) |
| Open Inverter Hardware | Quite flexible in its application. The Open Inverter can be used to build a custom inverter itself where you supply the high power and high voltage components to create your own inverter, or to be used as the basis to take over control of OEM inverters so that they can drive nearly any attached motor to that inverter. |
| Open Inverter Software | Two of the more important software aspects to master are below. |
| CAN communication
| Parameters
Open Inverter Related Projects (Control Boards/VCUs)
| Project | Description / Notes |
| Tesla Small Drive and Large Drive Units: | Commonly there is a large drive unit and small drive unit available from the Model S.
| Lexus GS450h Drivetrain: | The GS450h contains a gearbox (where the motors are located).
| Prius Generation 3 Inverter: | A cheap available inverter from the popular Prius hybrid, this
board goes inside that inverter and allows you to control the features of it. |
| Auris/Yaris Inverter: | Similar to the Prius board, there's subtle differences between them
and therefore the need for a separate board. |
| Nissan Leaf Gen2 Board | Replaces the nissan OEM logic board with a rev 3 openiverter main board |
| Ford ranger ev board | openinverter kit for the ford ranger ev |
| All Control Boards / OEM Inverters | |
Open Inverter Renewables Projects
Recently added to the forums are projects and discussions around turning the Open Inverter project towards capturing, storing and using renewable energy.
