Main Page Old
Before you begin:
Please take the time to read.
The information provided on this wiki and the support forums is intended as information only. The Open Inverter project and its contributors take no responsibility for how you use the information contained within these pages, nor any liability for injuries, or death, that may result from your actions.
Consider donating to the many developers that have made all this possible and to help keep making things possible: www.patreon.com/openinverter, https://www.evbmw.com/, https://www.paypal.com/paypalme/celeron55
Welcome to the open inverter community
Legalities
Different countries have different legislation, if you want you car to certified for the road in your country please take the time to review this section. It might save you going down the wrong direction and creating something that can never be driven, or incur costs.
The open inverter project originates from Johannes Hübner designing/building his own open source AC motor controller, dubbed the "open inverter"
With the rising popularity/availability of hybrid and electric vehicles, there is a growing supply of high quality and relatively inexpensive parts from auto-wreckers.
- EV conversion
- Energy storage
- Power generation
- Charging infrastructure
- etc.
- Motor Controllers
- 1-3 phase power converters
- DC/DC converters
- buck/boost converters
- Vehicle integration
- etc.
such efforts include:
- Mainboard/brain replacement
- CANBUS/LINBUS
- Sync serial
- FlexRay
- PWM
- etc.
Hardware | Firmware | Web Interface |
The design and development of the control hardware based around an STM32F103 chip. This provides the control signals to the power stage and on to the attached components. | The development of the code that goes on the STM32F103 chips and determines, amongst other things what signals are sent to the power stage and the attached components. | Using an ESP8266 chip, the development of a simple web based interface to adjust the parameters on the firmware chip and to display values returned from the chip, for example motor speed (RPM). |
Getting Started
It is recommend reading the Glossary of Terms before continuing further.
EV conversions:
- Motors
- Inverter
- Batteries
- DC/DC Converters
- HV Junction Box
- Heaters
- HVAC
- Brake Assist
- Vacuum Pumps
- Electronic Brake Boosters
- Power Steering
- Rapid Charging
OEM Parts:
- BMW
- Chevrolet
- Ford
- Hyundai
- Isabellenhütte Heusler
- Mercedes-Benz
- Mitsubishi
- Nissan
- Opel/Vauxhall
- Tesla
- Toyota/Lexus
FAQ
mechanical design database
Designs for:
- adapter plates
- motor couplers
- drive shaft flanges
- battery mounts
- etc.
Open Inverter (Core Project/s) |
Open Inverter Related Projects (Control Boards/VCUs) | |
core universal hardware and software components | ||
ZombieVerter VCU | Tesla Small Drive and Large Drive Units:
Open Inverter Hardware | ||
Lexus GS450h Drivetrain:
The GS450h contains a gearbox (where the motors are located). Using the ZombieVerter VCU, the inverter and the gearbox itself provide a powerful set up suitable for rear wheel drive set ups, replacing the existing longitudinally mounted gearbox. | ||
Prius Generation 3 Inverter:
Open Inverter Software |
Auris/Yaris Inverter:
Nissan Leaf Gen2 Board
replaces the nissan OEM logic board with a rev 3 openiverter main board | ||
Ford ranger ev board
openinverter kit for the ford ranger ev | ||
All Control Boards / OEM Inverters | ||
ParametersThe openinverter firmware uses a set of about 70 parameters to adapt it to different inverter power stages, motors and position feedback systems. Also it lets you calibrate the throttle pedal, change regenerative braking settings and so on.
Use inverter as a battery ChargerBoth the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here. |
