Category:Toyota
Revision as of 09:34, 25 September 2022 by Jason arnold (talk | contribs) (Known Inverter Catalogue: changes "Boards" column header to "Control Solutions" for clarity and pointed to VCU pages instead of CVT pages. Moved links pertaining to drivetrains to the entries under the "Model" column)
A landing page to start adding references to Toyota/Lexus and their suppliers part numbers and what vehicles that you might find them in.
The table below shows the part numbers of inverter units as labelled and as referenced by Toyota in their parts catalogue. Assembly part numbers may include a hyphen in the part number on some records. Label part numbers on the Lexus items are based on the lowest assembly part number. Links to part details are to the US sites for Toyota and Lexus.
Toyota/Lexus Inverter/Converter versions and Transaxle models
Generation Control Solution Label Part Number Assembly Part Number(s) Logic Board Part Number(s) Power Board Part Number(s) Model(s) Transaxle Model Code(s) Model Years
Gen 1 ZombieVerter VCU G9200-30040 G920030030 (RHD 2007)
G920030040 (LHD) G920030051
G920030061
G920030180
G920030090 (RHD 2012) (Current)
Lexus GS450h L110 GWS191 2007-2011
Gen 3 ZombieVerter VCU G9200-30132 G920030132
G92A030052
G927053010
Lexus IS300h
Lexus GS300h
Toyota Crown Hybrid
L210 AVE30
AWS210/AWS211
2013-2019
Gen 1 G9200-33050 G920033010
G920033020
G920033050
G920033100
G920033101 (Current)
F1759-30010-01 Toyota Camry Hybrid P311 AHV40 2007-2011
Gen 3 G9200-33171 G920033171
G920033172
Toyota Avalon Hybrid
Toyota Camry Hybrid
Lexus ES300h
P314 XX40
AVV50R
XVV60
2012-2018
2012-2017
2012-2015
Gen 1 N/A G9200-47070 G920047070
G920047071
G920047080
G920047090
Toyota Prius P110
P111
NHW11 2000-2003
Gen 2 Toyota Prius Gen2 [1] G9200-47110 Toyota Prius P112 NHW20 2004-2009
G92A0-48080 0489952020 - Toyota Transistor kit Toyota Highlander (Kluger AUS)
Lexus RX 400h
P310 MHU28 2006-2007
G92A0-48100 Toyota Highlander (Kluger AUS) P310 2008-2010
Gen 3 G9200-47150 G920047150 Toyota Prius P410 ZVW35 2010
Gen 3 G9200-47190 G920047190 Toyota Auris Hybrid
Toyota Corolla Hybrid
P410 2010
2016-2018
Gen 3 G9200-47210 G920047210 Toyota Prius P410 ZVW30 2010-2015
TBC ZombieVerter VCU (TBC) G9200-50040 G920050021 (RHD)
G920050040 (LHD) G920050060
G920050061
G920050063
G920050064
(Current)
Lexus LS600h L L110f UVF46 2007-2018
Gen 3 Auris/Yaris Inverter Logic Board G9200-52010 G920052010
G920152011
Toyota Aqua Hybrid P510 NHP10 2012-2017
Gen 3 Auris/Yaris Inverter Logic Board G9200-52011 G920059015
G92A052020
G920059035 (Current)
Toyota Prius C P510 NHP10R 2012-2017
Gen 3 G9200-52031 G920052031 Toyota Yaris Hybrid P510 NHP130R 2011-2017
Gen 3 Auris/Yaris Inverter Logic Board G9200-52060 G920059065 (Current) Toyota Prius C P510 NHP10R 2016
Gen 3? G9200-74010 G920074010 Toyota EQ EV
Scion iQ EV
30600-74010 KPJ10 2012-2013
TBC G9200-75010 G920075010
G920075011 (Current)
Lexus HS250h P311 ANF10 2009-2012
Gen 3 G9200-79015 G920079015
G920079025
G920079035 (Current)
Lexus CT200h P410 ZWA10 2011-2017
Gen 4 G9200-79045 G920079045 (Current) Lexus UX250h MZAH10 2018-
Gen 4 G9200-79055 G920079055 Lexus UX250h MZAH15 2018-
Gen 3? G92A0-11010 G92A011010 Lexus LC500h GWZ100 2017
Gen 3? G92A0-30020 G92A030020 (Current) Lexus GS350h GWL10 2012-2014
Gen 3? G92A0-33020 G92A033020
G92A033021 (Current)
Toyota Camry Hybrid
Lexus ES300h
AVX40
AVV50
AVV60
2012-2017
Gen 4 G92A0-33031 G92A033031 (Current) Lexus ES300h AXZH10 2018-2019
Gen 4 G92A0-42070 G92A042070 Toyota RAV4 Hybrid AXAH54 2019-
TBC G92A0-48051 G92A048051
G92A048121 G92A048122
G92A048260 (Current)
Lexus RX450h FWD P313? GYL10 2009-2015
TBC G92A0-48111 G92A048111 G92A048112
G92A048250 (Current)
Lexus RX450h AWD P313? GYL15 2009-2015
TBC G92A0-48230 G92A048230 Lexus RX450h P313? GYL20 2015-
TBC G92A0-48240 G92A048240 Lexus RX450h P313? GYL25 2015-
Gen 3? G92A0-78020 G92A078020
G92A042040 (Current)
Lexus NX300h P314 AYZ10 2015-2016
Gen 3? G92A0-58020 G92A042050 (Current) Lexus NX300h P314 AYZ15 2017-
Gen 4 G92B0-47011 G92B047011 Lexus UX250h (Rear) MZAH15 2019-
Wiring & Parts Reference
450 pages of Toyota wiring connections diagrams and part numbers https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
Control Schemes
OEM (Toyota Sync Serial)
Details about controlling unmodified Toyota Inverters via Toyota's native serial protocol (a.k.a. Sync Serial) can be found here: Toyota Inverters
Products that support this control scheme include the ZombieVerter VCU and the (now deprecated) Lexus GS450h VCU.
OI-based
Prior to the release of the ZombieVerter VCU project, Toyota/Lexus inverters were controlled using OI logic boards. Several options/configurations exist for various inverters:
