Toyota P111 CVT
(Redirected from Toyota/P111 CVT)
Description
The P112 is considered a second generation e-CVT.
Model Code
Applications
- Toyota Prius (1998-2003)
Specifications
MG1
Rated Voltage: 273.6V
Max Output: ?
MAX RPM: 6500
Power split device planetary gearset ratio is 3.6:1.
MG2
Max Output Power: 33 KW (44 HP)
Max Output Torque: 350 NM (258 lb ft)
Max RPM: 6500
Final Drive Ratio
MG2 to final drive ratio 3.901:1
Ring to pinion gear ratio 2.885:1
Oil Pump
Fluid Capacity
4.6L of Toyota Type T-IV fluid.
Weight
??? lbs
MG1 Stator
MG2 Stator
MG1 Resolver and Temperature Sensor
MG2 Resolver
MG2 Temperature Sensor
Park Shift Linkage
Reference
Weber State University: 1998 - 2003 Prius Transaxle - P111 Deep Dive
