ZombieVerter VCU
Revision as of 01:42, 13 October 2025 by Bratitude (talk | contribs)
ZombieVerter VCU board (NOTE: V1.2 is preproduction, V1.a is the current latest hardware revision)
Features
Hardware:
  • On-board WiFi
  • 3x high side PWM drivers
  • 5x low side outputs
  • 3x CANbus interfaces
  • LIN bus
  • sync serial interface
  • OBD-II interface
  • etc.
Software:
  • Web based user interface
  • Contactor control
  • Charger control
  • Charge timer
  • Motor (inverter) control
  • Heater control
  • Water pump control
  • Coolant fan control
  • Throttle mapping
  • Motor regen
  • BMS limits
  • IVT shunt initialization
  • Data logging and graphing
  • etc.
Motors/Drive units:
Chargers/DCDCs:
Heaters:
BMS:
Vehicle Integration (for CANbus control of dash, etc.):
  • BMW E9x CAN support
  • Mid-2000s VAG CAN support
  • Subaru CAN support
Resources
* IMPORTANT NOTE: only design files for PCB V1 are publicly available on GitHub, design files for the latest PCB release (V1.a) are only available through Damien Maguire's Patreon and require membership at the Design Files tier or higher.
Assembling the VCU
The enclosure kit options:
  2. Connector and pins[2]
  3. Pre-wired connector [3]
Wiring
VCU pinout diagram
Each device requires different wiring setups, settings and power requirements.
Vehicle-specific configurations
Power wiring
  • Pin 55 to 12V- ground
  • Pin 56 to 12V+ positive
  • general zombie and battery box wiring
    Pin 32 to ground pin on a 12V relay
  • Relay positive pin to 12V+
  • One of the relays switch pin to 12V+
  • Leaf inverter enable pin
  • Leaf PDM enable pin
  • Mitsubisihi OBC enable pin
Contactor wiring
  • ISA IVT shunt
  • Nissan leaf inverter
  • BMW S-BOX
  • etc.
  • Pin 31 for the negative contactor
  • Pin 33 for the positive contactor
  • Pin 34 for the pre-charge contactor
Throttle pedal wiring
  • Pin 45 to throttle grounds
  • Pin 46 to throttle channel 2
  • Pin 47 to throttle channel 1
  • Pin 48 to throttle positives
  • Pin 15 to "on" switched input (key switched to "on")
  • Pin 52 to "start" momentary input (momentary key switched "ignition")
Forward and Reverse
  • Pin 53 reverse
  • Pin 54 forward
Brake signal
  • Pin 49 need to be pulled high (connected to 12V +) when brake is pressed
Input/output pins
Low side Outputs.
  • GP Out 3
  • GP Out 2
High side PWM.
  • PWM 3
  • PWM 2
  • PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:
Pin IN/OUT/PWM Function
ChaDemoAIw OUTPUT activates when Chademo charger handshake initiates
OBCEnable OUTPUT activates as part of the ExtCharger module
HeaterEnable OUTPUT activates only in run mode and when coolant pump is on*
RunIndication OUTPUT activates when zombie is in run mode
WarnIndication OUTPUT activates when a error occurs with the ZombieVerter
CoolantPump OUTPUT activates during precharge, usually used for coolant pumps
NegContactor OUTPUT activates when the negative contactor needs to be closed. ie precharge, run, charge mode, etc
BrakeLight OUTPUT activates when a set brake light on threshold value is met
ReverseLight OUTPUT activates when reverse direction is selected
CoolingFan OUTPUT activates when FanTemp setpoint is reached
HVActive OUTPUT activates when contactors are closed and VCU is in run or charge mode
BrakeVacPump DIGITAL OUTPUT activates when BrakeVacSensor threshold value is met
CpSpoof PWM OUTPUT used to spoof CP signal to OBC when using a charging interface such as FOCCCI or I3LIM
GS450Hpump PWM OUTPUT used to run GS450H oil pump
HeatReq DIGITAL INPUT
HVRequest DIGITAL INPUT NOT FUNCTIONING
DCFCRequest DIGITAL INPUT Chademo Charge Interface enable contactors to charge
ProxPilot ANALOGUE INPUT detects when charge cable is plugged in
BrakeVacSensor ANALOGUE INPUT vacuum sensor input, use for triggering BrakeVacPump DIGITAL OUTPUT
PWMTim3
Proximity Pilot
Video explaining the setup and demonstration.
Initial start-up and testing
Powering up and connecting to the web interface
The following is required
  1. A fully built ZombieVerter VCU
  2. Two wires for power
  3. 12V power supply
  4. Computer/tablet for accessing the web interface
How to access the web interface
  1. Provide stable 12V power to pins 55, 56 on the ZombieVerter
  2. The on-board LED light "acty" should be now flashing
  3. Using your computer, connect to the ZombieVerters WIFI access point. SSID: "inverter" or "zom_vcu"
  4. Password is: inverter123
  5. In a web browser navigate to: 192.168.4.1
  6. The openinverter web interface should now load!
Configuration
*work in progress*
full list and overview of ZombieVerter Parameters and Spot Values
Basic parameters and spot values
Throttle
  • revlim is a rev limiter
Contactors
  • ISA
  • SBOX
  • VAG
  • LEAF
Forward/Reverse
input options:
  • switch
  • button
  • switchReversed
  • buttomReversed
work in progress
Charger
work in progress
Input Values
Errors, Common issues
Input Values:
  • "din_break" does not show "on", it must be off to allow potnom to be shown.
    • check wiring setup
  • UDC value updates during precharge.
    • check that your UDC value source is configured correctly (shunt type, proper can bus, ect)
    • check your contactor wiring.
      • some contactors are polarity sensitive
      • are they wired to be low side switched?
  • check can H/ can L wiring
  • is there too many devices sharing one can bus? (possible can id collision)
  • check inverter power relay wiring
    • is the inverter/charger/bms "ignition"/ "enable" pin driven via a zombie controlled relay?
    • is the relay firing during preacharge?
Software
Initializing an ISA Shunt:
  1. Wire the ISA shunt to 12V+ and canbus input.
  2. Under shunt can in the web interface, select the canbus the shunt is connected to
  3. Hit save parameters to flash.
  5. Select "Init"
  6. Hit save parameters to flash
  7. Power cycle the vcu and shunt at same time (they should be on same 12V feed anyway).
  8. The shunt will initialize.
  9. Select ISAMode "normal"
  10. Save to flash again
  11. Reboot the VCU
page with ZombieVerter parameters and their value ranges, ZV pinmap etc.
Troubleshooting
Serial Connection
Recovering the ZombieVerter from a failed update
  1. Firstly, download the bootloader from here and latest ZombieVerter firmware from here as .hex files. This ensures you don't need to know the address of the file and avoids user error when flashing via STLink
  2. Download STMCubeProgrammer from here (other STM flashing softwares are available but the following instructions are based on what has worked for me).
  3. Upgrade the firmware on your STLink dongle using STMCubeProgrammer. I'm not sure if this is 100% necessary but seems prudent.
  4. Connect the Clock (SWclk), Gnd and Data (SWDio) of your STLink to the ZombieVerter test points. On the ZombieVerter Board, they are labelled C, G, D.
  5. Connect 12V and Gnd to the ZombieVerter main power pins and ensure your STMCubeprogrammer is able to connect to it. I also disconnected the wifi board just incase.
  6. Perform a "full chip erase", then reflash the latest bootloader and firmware hex files.
  7. Remove your STLink from the ZombieVerter, connect the wifi board and check connectivity.
  8. Begin ZombieVerter-ing.
ESP32 CanBus Web Interface
