Volkswagen Heater
Jump to navigation
Jump to search
General Information [1]
- Operating Voltage: 280VDC - 450VDC
- Power: 5kW (7kW "boost" between 350-450V)
- Control via LIN by integrated electronics
- Temperature control by integrated sensor
- 3d Scan: https://grabcad.com/
- Must be used in an inverted orientation with the sockets situated below as air can be left trapped in the heater element zone causing steam to be explosively generated
- Fluid connection (mm): 20 (Nozzle dimensions according to DIN3021-3[2])
- Dimensions L x W x H (mm): 210 x 73 x175
- Weight (kg): ~1,7
Pinout/Connectors
HV connector: TE 4-2103177-5 (HVA 280 series - key "E")
- HV+ near to the body,
- HV- far from the body
LV connector: TE 1-1394416-1
- Pin 1 is permanent 12V
- Pin 2 is GND
- Pin 4 is LIN
- Pin 5 is HV Interlock loop passthrough (ref. right terminal highlighted with Blue in picture)
- Pin 7 is HV interlock loop passthrough (ref. left terminal highlighted with Blue in picture)
LIN Bus Communication
| ID | Description | Length | Checksum Type | Byte 0 | Byte 1 | Byte 2 | Byte 3 | Byte 4 | Byte 5 | Byte 6 | Byte 7 |
| Dec: 28
Hex: 0x1C PID: 0x9C |
Control, every 50ms | 2 | Enhanced | Power
0-100% scale: x1 |
Last bit: Start/Stop | ||||||
| Dec: 48
Hex: 0x30 PID: 0xF0 |
Feedback | 8 | Enhanced | HV Current:
Unit: Amp Scale: 0.25 |
?? | ?? | ?? | LV Voltage:
Unit: Volt Scale: 0.1 |
Module Temp
Unit: Celcius offset:-50 |
Temperature in
Unit: Celsius offset:-50 |
Temperature out
VW Part Numbers
Heater:
- 3Q0 963 231 A
- 3Q0 963 231 C
- 3Q0 963 231 E
Cable assemblies:
- HV cable is 3Q0 971 475 or 5Q0 971 475
- LV cable appears to be 1J0 973 714
- ↑ http://datasheets.dbk-worldwide.com/EN/Datasheets/WireHeaters/DBKITM_HV%20Water%20heater_eng.pdf (Backup: Web Archive)
- ↑ https://web.archive.org/web/20250109134824/https://images.carid.com/mubea/items/pdf/hose-spring-band-clamp-brochure.pdf
- ↑ https://openinverter.org/forum/viewtopic.php?p=26604#p26604
