Main Page Old
Before you begin:
Open inverter is a suite of open source hardware and software projects for building, modifying and controlling a variety of power electronics.
projects originates from Johannes Hübner building a opensource ac motor controller, dubbed the "open inverter".
The project now has spanned over many different areas in ev and hybrid vehicles components, such as:
- AC motor controllers
- 1-3 phase power converters
- dc/dc converts
- buck/boost converters
- battery management systems
With the rising popularity and avalibity of hybrid and electric vehicles, there is a growing supply of parts. The open inverter community's goal is to repurpose many of these components for ev conversions and other projects.
The open inverter community is growing and moving quite quickly, to stay up-to-date with the latest developments and findings, please check out the forums
consider contributing to www.patreon.com/openinverter and to https://www.evbmw.com/
The open inverter motor controller project consists of three main aspects:
Getting Started
Inverter variants available:
Open Inverter (Core Project/s) |
| core universal hardware and software components | custom hardware and software designed to work with particular components.
which are based on the core open inverter hardware or software stack. | |
| ZombieVerter VCU (Testing/Developement - NOT for sale at present) | Tesla Small Drive and Large Drive Units:
Open Inverter Hardware | ||
Open Inverter Software |
Auris/Yaris Inverter:
| Nissan Leaf VCM:
this vehicle control board plugs into the Nissan Leaf inverter externally and controls it via CAN | ||
replaces the nissan OEM logic board with a rev 3 openiverter board for full control | ||
ParametersThe openinverter firmware uses a set of about 70 parameters to adapt it to different inverter power stages, motors and position feedback systems. Also it lets you calibrate the throttle pedal, change regenerative braking settings and so on. Working parameter sets can be found in the openinverter parameter database | ||
Use inverter as a battery ChargerBoth the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here | ||
Further Components
- Motors
- Batteries
- Charger
- DC/DC Converter
- HV Junction Box
- Heaters
- Other various components
- Vacuum Pumps
- Heaters
- Air Conditioning
- Information Displays
- etc.
FAQs
Open Inverter CAN std.
Glossary of Terms
Legalities
Conversion Projects
- VW Polo 86C Conversion
- Touran Conversion
- toyota gt86 nissan leaf motor
- Porsche Boxster 986 Tesla conversion
- Further Projects on the forum
