ZombieVerter VCU
(Redirected from Nissan Leaf VCU)
ZombieVerter VCU board (NOTE: V1.2 is preproduction, V1.a is the current latest hardware revision)
Features
Hardware:
  • On-board WiFi
  • 3x high side PWM drivers
  • 5x low side outputs
  • 3x low side inputs
  • 3x canbus
  • LIN bus
  • sync serial
  • etc.
Software:
  • Web based user interface
  • Battery system
    • contactor control
    • precharge control
    • BMS limits
    • shunt data
  • charging system
    • on board charger control
    • charge interfaces
    • charging timers
    • dcdc control
    • 12v battery tending
  • Motors
    • motor/inverter control
    • throttle mapping
    • regen mapping
  • thermal management
    • water pump control
    • fan control
    • cabin heater control
  • OBD-II interface
  • Data logging and graphing
  • mappable canbus
  • etc.
Motors/Drive units:
Chargers/DCDCs:
Heaters:
BMS:
Vehicle Integration (dash, heat, etc):
  • 1998-2005 BMW 3-series (E46)
  • 1996-2003 BMW 5-series (E39)
  • 2001-2008 BMW 7-series (E65)
  • BMW E9x
  • Mid-2000s VAG
  • Subaru
Resources
Assembling the VCU
Enclosure kit options:
  2. Connector and pins[2]
  3. Pre-wired connector [3]
  4. 3d printable enclosure
  5. zombie backpack
building your own board:
*only design files for PCB V1 are publicly available on GitHub, design files for the latest PCB release (V1.a) are only available through Damien Maguire's Patreon and require membership at the Design Files tier or higher.
Wiring
General zombieverter wiring:
Vehicle-specific configurations
Generic input and outputs functions:
parameter type Function
ChaDemoAIw OUTPUT activates when Chademo charger handshake initiates
OBCEnable OUTPUT activates as part of the ExtCharger module
HeaterEnable OUTPUT activates only in run mode and when coolant pump is on*
RunIndication OUTPUT activates when zombie is in op mode "run"
WarnIndication OUTPUT activates when zombieverter is in a error state
CoolantPump OUTPUT activates during precharge, usually used for coolant pumps
NegContactor OUTPUT activates when the negative contactor needs to be closed. ie precharge, run, charge mode, etc
BrakeLight OUTPUT activates when a set regen threshold value is met
ReverseLight OUTPUT activates when reverse direction is selected
CoolingFan OUTPUT activates when "FanTemp" setpoint is reached
HVActive OUTPUT activates when the HV system is live, often used for switched 12v supply to the outlander OBC
BrakeVacPump DIGITAL OUTPUT activates when "BrakeVacSensor" threshold value is met
CpSpoof PWM OUTPUT used to spoof CP signal to OBC when using a charging interface such as FOCCCI or I3LIM
GS450Hpump PWM OUTPUT used to run GS450H oil pump
HeatReq DIGITAL INPUT
HVRequest DIGITAL INPUT brings the HV system live
DCFCRequest DIGITAL INPUT used to enter zombie into "DCFC" op mode (chademo)
ProxPilot ANALOGUE INPUT detects when charge cable is plugged in
BrakeVacSensor ANALOGUE INPUT vacuum sensor input, use for triggering BrakeVacPump DIGITAL OUTPUT
PWMTim3
Zombieverter parameters + setup
Parameters:
Powering up and connecting to the web interface
The zombieverter parameters must be configured in the web interface before powering on the EV system.
first isolate the zombiverter before applying 12v power for the first time:
The following is required
  1. A fully built + programed Zombieverter VCU
  2. 12V power supply
  3. Computer/tablet for accessing the web interface
How to access the web interface
  1. Provide stable 12V power to the Zombieverter:
    • GND (pin55)
    • 12V+ (pin56)
  2. The on-board LED light "acty" should be now flashing (if not see Zombieverter programing)
  3. Using your computer, connect to the Zombieverters WIFI access point. SSID: "inverter" or "zom_vcu"
  4. Password is: inverter123
  5. In a web browser navigate to: 192.168.4.1
  6. The web interface should now load! (if having issues, power cycle the zombie)
Troubleshooting
zombieverter not going into op mode "run" :
spot Values:
  • "din_break" does not show "on", it must be off to allow potnom to be shown.
    • check wiring setup
  • UDC value not updates during precharge.
    • check that your UDC value source is configured correctly (shunt type, proper can bus, ect)
wiring:
  • check contactor wiring.
    • some contactors are polarity sensitive
    • is the negative contactor output pin set correctly in the web interface?
    • are they wired to be low side switched?
  • check can H / can L wiring
    • are can lines set to the correct bus? ie leaf motor wired to can 2 and set inverter = can 2
    • is there too many devices sharing one can bus? (possible can id collision)
    • is canbus terminated? ie reads 60ohms when powered off?
  • check IGN power relay wiring
    • is the "ignition"/ "enable" pin on your charger/inverter/etc driven via a zombie controlled relay?
    • is the relay firing during startup?
ESP32 CanBus Web Interface
flashing firmware and device config
*zombiverter boards from the webshop, come pre-programed and do not require any additional programing to work.
  • re-flashing a bricked board
The zombieverter has the ability to configure some devices connected to it, make them "plug and play"
  • ISA/IVT shunt (after initialisation)
  • foccci
Initializing an ISA Shunt:
  1. Wire the ISA shunt to 12V+ and canbus input.
  2. Under shunt can in the web interface, select the canbus the shunt is connected to
  3. Hit save parameters to flash.
  5. Select "Init"
  6. Hit save parameters to flash
  7. Power cycle the vcu and shunt at same time (they should be on same 12V feed anyway).
  8. The shunt will initialize.
  9. Select ISAMode "normal"
  10. Save to flash again
  11. Reboot the VCU
