Main Page Old
Welcome to the open inverter wiki, please take your time to read!
The open inverter community is growing and moving quickly.
Stay up-to-date with the latest developments and findings, please check out the forums
To edit the wiki, login with your forum credentials.
Before you begin:
Please take the time to read. Developers of various projects are often bombarded with private messages and emails. Managing these emails and question is a extremely large undertaking. Please read, and take the time to understand the information available here and across the web if you don't understand a topic. Developers are not your personal support team!
Consider donating to the many developers that have made all this possible: www.patreon.com/openinverter, https://www.evbmw.com/, https://www.paypal.com/paypalme/celeron55
The information provided on this wiki and the support forums is intended as information only. The Open Inverter project and it's contributors take no responsibility for how you use the information contained within these pages, nor any liability for injuries, or death, that may result from your actions.
The open inverter project originates from Johannes Hübner designing/building his own open source AC motor controller, dubbed the "open inverter"
With the rising popularity/availability of hybrid and electric vehicles, there is a growing supply of high quality and relatively inexpensive parts from auto-wreckers.
- ev conversion
- energy storages
- power generation
- charging infrastructure
- etc
- motor controllers
- 1-3 phase power converters
- dc/dc converts
- buck/boost converters
- battery management systems
- vehicle integration
- etc
As a results, there is a growing collection of open source software and hardware designed for the never ending list of OEM parts.
Theres a variety of methods of repurposing these OEM components. Methods here are generally chosen with future proofing in mind , reducing chances of firmware or software updates from the manufacture "bricking" or blocking the open source control efforts.
such efforts include:
- mother board/brain replacement
- canbus/linbus
- sync serial
- flexray
- pwm
- firmware/software reprogramming
- ect
Resulting in many bespoke boards running the main open inverter software or other open/semi-open source code designed to ether replace OEM mother boards or VCUs.
Hardware | Firmware | Web Interface |
The design and development of the control hardware based around an STM32F103 chip. This provides the control signals to the power stage and on to the attached components. | The development of the code that goes on the STM32F103 chips and determines, amongst other things what signals are sent to the power stage and the attached components. | Using an ESP8266 chip, the development of a simple web based interface to adjust the parameters on the firmware chip and to display values returned from the chip, for example motor speed (RPM). |
Getting Started
Its recommend reading the Glossary of Terms before continuing further.
EV conversions:
A few main parts are needed for a ev conversion, such as:
- Motors
- inverters
- Batteries
- Chargers / charge controllers
- DC/DC Converters
- HV Junction Box
- Heaters
- brake assist
- Vacuum Pumps
- electronic brake boosters
OEM Parts:
A variety of OEM manufacture parts members of the community have reversed engineered for custom use cases:
FAQ
Open Inverter (Core Project/s) |
core universal hardware and software components | ||
ZombieVerter VCU | Tesla Small Drive and Large Drive Units:
Open Inverter Hardware | ||
Lexus GS450h Inverter / VCU:
Prius Generation 3 Inverter:
Open Inverter Software |
Auris/Yaris Inverter:
Nissan Leaf Gen2 Board
replaces the nissan OEM logic board with a rev 3 openiverter main board | ||
Ford ranger ev board
openinverter kit for the ford ranger ev | ||
All Control Boards / OEM Inverters | ||
ParametersThe openinverter firmware uses a set of about 70 parameters to adapt it to different inverter power stages, motors and position feedback systems. Also it lets you calibrate the throttle pedal, change regenerative braking settings and so on. Working parameter sets can be found in the openinverter parameter database | ||
Use inverter as a battery ChargerBoth the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here |
Open Inverter CAN std.
Legalities
