Main Page Old
Getting Started
The open inverter project consists of three main aspects:
- Reference designs for the control hardware using an STM32F103
- The inverter firmware, which can control AC Induction motors or Permanent Magnet Synchronous Motors
- An easy to use web interface.
There are two variants available:
- Kit for use with your own power section. If you have received a kit you are probably looking for build instructions.
- Kit for use with existing power sections, including drop in boards for Tesla small and large drive units.
Once you have the inverter parts, you will need additional components for your EV conversion:
- Motor
- Batteries
- Charger
- DC/DC Converter
- HV Junction Box
- Other various components
More detailed information on these items can be found on the EV Conversion Parts page.
FAQs
Open Inverter Hardware
- Schematics and Instructions - for the "vanilla" inverter kit.
- Main Board Version 3
- Main Board Version 2
- Main Board Version 1
- Sense Boards
- Gate Driver
- 4-cell BMS
- Hardware Theory of Operation
- Legacy Sensor Board
Open Inverter Software
- Using FOC Software
- Downloads
- Features
- Web Interface
- Battery Charging
- Errors
- CAN communication
- Parameters
- Configuration Files
- Software Theory of Operation
Open Inverter CAN std.
Glossary of Terms
