Tesla Model S/X GEN2 Charger
tesla gen2 ac charger
Tesla Gen2 X-Ray
Important Considerations
Output Voltage Range
HEED DAMIEN'S WARNING:[2]
Supported Tesla Part Numbers (TPN)
TPNs to avoid:
TPNs tested and known good:
  • 1014963-00-C/E/F/J/K/L
    • 1014963-00-C [4]
Supported Software Revisions
Cooling
Replacement Control Boards
Charger Connections
Connector part numbers
  • housing: 044441-2006
Replacement board connectors
  • SM24B-CPTK-1A-TB(L)
  • IPS1-115-01-L-D, SAMTEC
    • Has all 30 pins.
Programming
You'll need a ST-LINK/V2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
Two options:
External CAN bus
Gen2 Charger V5aB2 logic board with CAN wired to external pins
Charger CAN protocol - up to version 1.06.R
Charger CAN protocol - after version 1.06.R
LR: Personally I think the data for DC voltage limit is incorrect. The above states Motorola but only when I set all signals (so not only DC voltage limit as also the start bit count (sometimes) varies) to Intel it works for me.
Parameter view of commercial firmware
openinverter style charger firmware
  • DC current control
Note: Its recommend that you change it. Nobody wants to drive and have some joker with a phone finding this information and accessing your charger.
Missing IC4 Chip
Image of Tesla Gen2 charger board with missing IC4 chip
Registration
Latest Software for V5 boards and later
Tesla Model S/Tesla Gen23 V5 Software
Additional Resources
The Tesla Project : 10 Kw Gen 2 Charger
The Tesla Project : Charger Progress
The Tesla Project : 10kW Charger Charging
The Tesla Project : More Charger Hacking
The Tesla Project : Charger 10kw Run
Common Issues
