ZombieVerter VCU
- Development thread
- github repo
- fully built VCU boards
- partially-built VCU boards
There is a growing supply of OEM(original equipment manufacture) EV and hybrid parts; inverters, chargers, dc/dc converters, heaters, etc, requiring some control method in order to reuse them in a EV conversion.
After reverse engineering the communication signals for these devices, we need a control board to tell the device in question what todo. These devices often talk different "languages" some use CANBUS, LINBUS, sync serial, PWM, etc
hence the "zombieverter" VCU
The Zombieverter includes the following:
hardware features:
- on board WIFI
- 3x High side PWM drivers
- 5x low side outputs
- 3x CANbus interfaces
- Linbus
- sync serial interface
- OBD-II interface
Software features:
- web based user interface
- contactor control
- charger control
- charge timer
- motor(inverter) control
- heater control
- water pump control
- coolant fan control
- throttle mapping
- motor regen
- cruise control(?)
- BMS limits
- IVT shunt initialization
- data logging and graphing
after connecting to the zombiverters WIFI network, you can access the web interface via: 192.168.4.1
- Chademo dc fast charging
- BMW E9x CAN support
- Mid-2000s VAG CAN support
- subaru CAN support
- EVS-Charge Port Controller
- VAG/VW cabin heater via lin
- STM32-CAR project
- Openinverter
- ISA library
Enclosure and header
Looking to build a zombiverter VCU your self or your kit comes with missing hardware? see the Zombiverter hardware page for build instructions
The enclosure kit:
options:
- blank connector 211PC562S8009
- prewired with 3m long leads. 211PC562S0008
The original connectors are from aptiv (delphi), where you can find drawings and 3d models:
- aptive 56pin connector
- aptive 56pin header
aliexpress/alibaba knock-offs:
- Enclosure Kit with Header, connector and pins[1]
- Connector and pins[2]
- Prewired connector with 3M leads (limited colors which will not match standard wire coloring conventions)[3]
wiring
Pin Out Diagrams
Leaf stack with zombiverter
Tesla SDU with Zombieverter
Notes:
- This drawing is intended to show the minimum components and connections needed for Zombieverter control of an OI SDU via Can bus. Adapting power and Can bus connections for other OI inverters should function in the same manner, but this needs verification.
- All power connections must be fuse protected. Fuses are not shown for simplification.
- The following observations were made using Zombieverter firmware 2.20A and SDU firmware 5.35R:
- The Zombieverter does not enable inverter power prior to entering PreCharge mode. An external device other than the inverter is required to supply the udc measurement for switch to Run mode. This function is supported by the shunt and BMS options available in the Zombieverter parameters.
- A third device must be on the Can bus with the Zombieverter and Inverter.
- Requirements 1. and 2. are satisfied in the drawing by the IVT shunt.
- All devices except the Zombieverter are shown as powered by the ignition switch. Some devices may need to move to permanent 12V supply to support other functions, such as charging.
- An inverter power relay is required for Zombieverter control.
- Can mapping to pass data and commands from the Zombieverter to the inverter is hard coded in the firmware for both devices. Manual mapping is required for the inverter to transmit data to the Zombieverter. The Zombieverter is hard coded to receive this data. The following values need to be manually mapped in the inverter. Note: mapping uses hex address values, multipliers may need to change to provide correct values (confirm in Zombieverter spot values), inverter udc gets mapped to inv udc in the Zombieverter.
| Spot Value | Hex Address | Offset | # Bits | Multiplier | Map |
| speed | 400 | 0 | 16 | 1 | Tx |
| tmphs | 410 | 0 | 16 | 10 | Tx |
| udc | 420 | 0 | 16 | 10 | Tx |
| opmode | 430 | 0 | 8 | 1 | Tx |
Initial start-up and testing
Wifi Setup
Configuration Setup
Software
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
./Stm32-vcu/libopeninv/src/
Software update
Initializing an ISA Shunt
Under Comms in the web interface, there is now an ISAMode option. By default its in "Normal" (Off on Rev 2). If you want to initialize a new shunt, connect it up, power on the shunt and vcu, select "Init" (On on Rev 2), hit save parameters to flash. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway). The shunt will initialize. Select ISAMode "normal" (Off on Rev 2), save to flash again and reboot again. The shunt should now be up and running. If the shunt doesn't initialise correctly, separate the shunt and VCU supplies and power cycle the VCU two or three seconds after the shunt power is cycled. This has fixed an initialise issue for a number of ISA shunts and possibly requires a VCU code fix that delays the initialising for a few seconds to allow the shunt to power up.
Low side Outputs.
- GP Out 3
- GP Out 2
High side PWM.
- PWM 3
- PWM 2
- PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:
- WarnIndication - OUTPUT
- HeatReq - DIGITAL INPUT
- PWMTim3 -
Proximity Pilot
Firmware
Troubleshooting
Serial Connection
If your ZV fails on the update and the Web User Interface is reporting "firmware: null" it's possibleyou'll need to reflash the firmware, bootloader via an STLink and/or delete any existing .bin and .Json files from the files section.
- Begin Zombieverter-ing.
