Tesla Model S/X GEN2 Charger
tesla gen2 ac charger
Tesla Gen2 X-Ray
Important Considerations
Output Voltage Range
HEED DAMIEN'S WARNING:[2]
Supported Tesla Part Numbers (TPN)
TPNs to avoid:
TPNs tested and known good:
  • 1014963-00-C/E/F/J/K/L
    • 1014963-00-C [4]
Supported Software Revisions
Cooling
Replacement Control Boards
Charger Connections
Connector part numbers
  • housing: 044441-2006
Replacement board connectors
  • SM24B-CPTK-1A-TB(L)
The 30 pin connector is very difficult to desolder and resolder. Replacement P/N is:
Programming
You'll need a ST-LINK/V2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
Two options:
External CAN bus
Gen2 Charger V5aB2 logic board with CAN wired to external pins
Charger CAN protocol - up to version 1.06.R
Charger CAN protocol - after version 1.06.R
LR: Personally I think the data for DC voltage limit is incorrect. The above states Motorla but only when I set all signals (so not only DC voltage limit as also the start bit count (sometimes) varies) to Intel it works for me.
Parameter view of commercial firmware
openinverter style charger firmware
  • DC current control
Note: Its recommend that you change it. Nobody wants to drive and have some joker with a phone finding this information and accessing your charger.
Registration
Commercial firmware usage manual
We will go over all of them.
idclim
iaclim
idcspnt
chargerena
udcspnt
udclim
timelim
timedly
The default value is -1 but this results in the charging waiting forever. You need to set this to 0 (or more) for the OBC to work.
inputype
  • Type2: Specifies one or more modules are operated on ONE common phase of a Type-2 EVSE. The limits imposed by cablelim and evselim (pilot signal) are distributed equally over the enabled modules. For example if you enable all 3 modules, the cable allows 32A but the EVSE only allows 16A, every module will run at 16/3=5.3A. Charging will start automatically as soon as proximity and a valid pilot signal is detected. Note: You must still have the D1 enable line high. All charge modes require D1 to be high.
  • Type2-3P: Specifies each module is connected to a different phase of a Type-2 EVSE. The limits imposed by cablelim and evselim are allowed for each module.
  • Type-2Auto: relies on input D2 to indicate that 3 phase is present (from external relay), to allow charging on either single or three phase automatically.
  • Type1: Like Type2 but cablelim is always assumed 40A.
  • Manual: Specifies one or more modules are operated on ONE common phase, power is distributed like in Type2 mode. Charging starts as soon as the enable pin "D1" goes high. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
  • Manual-3P: Specifies that each module is connected to a different phase of 3-phase outlet. Each module is allowed iaclim AC current. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
cancontrol
idckp/idcki
pin
Additional Resources
The Tesla Project : 10 Kw Gen 2 Charger
The Tesla Project : Charger Progress
The Tesla Project : 10kW Charger Charging
The Tesla Project : More Charger Hacking
The Tesla Project : Charger 10kw Run
Common Issues
