Tesla Model S/X GEN2 Charger
Important Considerations
Output Voltage Range
HEED DAMIEN'S WARNING:[2] |
Supported Tesla Part Numbers (TPN)
TPNs to avoid:
- 1014963-05-B and 1014963-05-C
TPNs tested and known good:
- 1014963-00-E/F/J/K/L
- 1014963-00-G is likely also good, just wasn't mentioned by name in the referenced thread
Supported Software Revisions
Cooling
The direction of flow in the cooling plate does not seem to matter.[4] The charger should likely be on the same cooling loop as the batteries themselves. This coolant loop should be separate from the loop with the motor and inverter (they get far too hot.) Limited testing (esp 110V, 1kw) can be done without the coolant lines hooked up. However, it would be unwise to attempt 10kw charging for any length of time without liquid cooling.
Replacement Control Boards
Charger Connections
A1 | A2 | A3 | A4 | A5 | B1 | B2 | B3 | B4 | B5 | B6 | |
OUT2 - AC present | D1 - enable | 12V supply | CANH | Control Pilot | |||||||
A6 | A7 | A8 | A9 | A10 | B7 | B8 | B9 | B10 | B11 | B12 | |
OUT1 - HV enable | D2 - 3p | GND | CANL | Proximity |
Connector part numbers
- housing: 044441-2006
- pins: 043375-3001 (18-20AWG), 043375-0001 (14-16AWG)
- housing: 10-way 19418-0014, 12-way 19418-0026
- pins: 33012-2002 (18-20AWG), 33012-2001 (14-16AWG)
Replacement board connectors
- SM24B-CPTK-1A-TB(L)
The 30 pin connector is very difficult to desolder and resolder. Replacement P/N is:
- IPS1-115-01-S-D-PL, SAMTEC - IPS1-115-01-S-D-PL - SOCKET, 2.54MM, 2X15WAY
Programming
You'll need a ST-LINK/V2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
- ST-LINK programming utility: https://www.st.com/en/development-tools/stsw-link004.html
- stm32_loader.hex https://openinverter.org/forum/viewtopic.php?f=7&t=1119
Two options:
- Charger_gen2_v5.hex https://github.com/damienmaguire/Tesla-Charger/tree/master/V5/Software/Binary
- openinverter style firmware https://openinverter.org/forum/viewtopic.php?t=1323 (only available via patreon for next few weeks)
External CAN bus
ID | Direction | Byte 0 | Byte 1 | Byte 2 | Byte 3 | Byte 4 | Byte 5 | Byte 6 | Byte 7 |
0x102 | Receive by charger | DC voltage limit MSB | DC voltage limit LSB | DC current set point | ==1 enable charging | SoC | |||
0x108 | Transmit by charger | Version=0 | Max DC voltage MSB | Max DC voltage LSB | Max DC current | ||||
0x109 | Transmit by charger | Version=0 | DC voltage MSB | DC voltage LSB | DC current | 0 when off, 5 when charging |
openinverter style charger firmware
- Support for the standard open inverter web interface
- Parameter handling as known from the inverter firmware (see picture)
- Spot value handling like inverter including plotting, gauges, and logging
- Over the air update like inverter
- DC current control
- CAN control as described above
By default all charger kits will have SSID : charger PASSWORD : charger123
Note: Its recommend that you change it. Nobody wants to drive and have some joker with a phone finding this information and accessing your charger.
Registration
Commercial firmware usage manual
We will go over all of them.
idclim
iaclim
idcspnt
chargerena
udcspnt
udclim
timelim
inputype
- Type2: Specifies one or more modules are operated on ONE common phase of a Type-2 EVSE. The limits imposed by cablelim and evselim (pilot signal) are distributed equally over the enabled modules. For example if you enable all 3 modules, the cable allows 32A but the EVSE only allows 16A, every module will run at 16/3=5.3A. Charging will start automatically as soon as proximity and a valid pilot signal is detected. Note: You must still have the D1 enable line high. All charge modes require D1 to be high.
- Type2-3P: Specifies each module is connected to a different phase of a Type-2 EVSE. The limits imposed by cablelim and evselim are allowed for each module.
- Type-2Auto: relies on input D2 to indicate that 3 phase is present (from external relay), to allow charging on either single or three phase automatically.
- Type1: Like Type2 but cablelim is always assumed 40A.
- Manual: Specifies one or more modules are operated on ONE common phase, power is distributed like in Type2 mode. Charging starts as soon as the enable pin "D1" goes high. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
- Manual-3P: Specifies that each module is connected to a different phase of 3-phase outlet. Each module is allowed iaclim AC current. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
cancontrol
idckp/idcki
pin
Additional Resources
The Tesla Project : 10 Kw Gen 2 Charger
The Tesla Project : Charger Progress
The Tesla Project : 10kW Charger Charging
The Tesla Project : More Charger Hacking
The Tesla Project : Charger 10kw Run
Common Issues
- The Tesla chargers are very sensitive to grounding. The case MUST be connected to vehicle 12v ground AND evse earth/ground when charging. [1]
- With V5aB2, If you do NOT use the external CAN bus or are not properly terminated, remember to close the solder jumper next to R1 under the WiFi module. When in doubt, check the resistance of the CAN bus with all devices off. It should be 60 ohms ideally. If you are not using the external CAN then it should be 120 ohms.
- People had problems with unreliable connectivity between ESP8266 & the charger board [2]
- Firmware 1.09 and 1.10 can lose the CAN map, making the logic board go silent, reset instructions here: [3]
- If a module within the charger is enabled (and all three are enabled by default) then it MUST see AC and DC voltage when charging starts. If it does not then no current will flow on any module. So, triple check your wiring before starting. It can be easy to mix up the line and neutral wires of the AC input. This will not blow up anything but it won't work either. Mixing up the DC wires is a recipe for a bad time.
- Some chargers are just raised wrong. As covered above, for reasons we don't know, some modules will simply refuse to work properly. Most often this will happen to chargers that were previously used in super charger stations but it can happen to chargers that were pulled from Model S cars as well. There is not yet any known fix for this. If it happens the only current solution is a different charger or you live with slow charging.
- Did you set the D1 enable pin to be high (+12v?) It must be high in ANY mode in order for charging to start. It is OK to tie it to the +12 incoming power if you are using something like Type2 where charging is controlled by the proximity and control pilot signals.
