Zombieverter Parameters and Spot Values
| Id | Name | VCU Pin | Unit | Min | Max | Default | Utilisation | Description |
| - General Setup | ||||||||
| 5 | Inverter | 0 | 8 | 0 | Selected Inverter to be controlled
0=None - No inverter to be controlled 1=Leaf_Gen1 - Nissan Leaf Gen1, 2 or 3 control via CAN 2=GS450H - Lexus GS450h via Clocked Serial 3=UserCAN - Not Used 4=OpenI - Open Inverter control board via CAN 5=Prius_Gen3 - Toyota Prius via Clocked Serial 6=Outlander - Outlander PHEV !!!Depreciated 7=GS300H - Lexus IS300h via Clocked Serial 8=RearOutlander - Misubishi Outlander PHEV via CAN | |||
| 6 | Vehicle | 0 | 8 | 0 | Vehicle to Integrate with0=BMW_E46 - BMW E46 via CAN and digital IO
1=BMW_E6x+ - BMW E6x and E9x and derivatives via CAN 2=Classic - Digital IO 3=None - No vehicle support functions 5=BMW_E39 - BMW E39 via CAN and digital IO 6=VAG - Tbc which supported vehicles 7=Subaru - Tbc which supported vehicles 8=BMW_E31 - BMW E31 via CAN and digital IO | |||
| 108 | GearLvr | 0 | 4 | 0 | Connected Gear Selector via CAN0=None - No CAN based gear selector used
1=BMW_F30 - BMW F series shifter via CAN 2=JLR_G1 - Jaguar Landrover Circular shifter via CAN 3=JLR_G2 - Jaguar Landrover Circular shifter via CAN 4=BMW_E65 - BMW E65 shifter via CAN | |||
| 78 | Transmission | 0 | 1 | 0 | BMW E31, E39, E46 | Type of gearbox for vehicle intergration0=Manual
1=Auto | ||
| 39 | interface | 0 | 4 | 0 | Type of CAN bus based charging interface used0=Unused - None Used
1=i3LIM - BMW I3 LIM 2=Chademo - Chademo via CAN 3=CPC - Charge Port Interface (Volt Influx Ltd) 4=Focci - Foccci CCS controller | |||
| 37 | chargemodes | 0 | 6 | 0 | Charger Used0=Off - None
1=EXT_DIGI - Digital signal control 2=Volt_Ampera - Gen 1 Ampera/Volt Charger via CAN 3=Leaf_PDM - Gen 1, 2 or 3 Nissan Leaf PDM via CAN 4=TeslaOI - Run Gen 2 or Gen 3 Tesla charger with OI board via CAN 5=Out_lander - Outlander PHEV Charger DCDC via CAN 6=Elcon - Elcon/TC charger protocol via CAN | |||
| 90 | BMS_Mode | 0 | 5 | 0 | Connected BMS over CAN0=Off - No BMS implementated
1=SimpBMS - SimpBMS/Victron via CAN 2=TiDaisychainSingle - via CAN 3=TiDaisychainDual - via CAN 4=LeafBms - Stock Nissan Leaf Gen1,2 or 3 BMS via CAN 5=RenaultKangoo33 | |||
| 88 | ShuntType | 0 | 3 | 0 | Current Shunt type used, also allows use of CAN based contactor boxes0=None - No Current Shunt Used
1=ISA - Isabelleheute Current Shunt Used 2=SBOX 3=VAG | |||
| 70 | InverterCan | 0 | 1 | 0 | If CAN inverter used | CAN bus used for Inverter0=CAN1, 1=CAN2 | ||
| 71 | VehicleCan | 0 | 1 | 1 | If Vehicle used | CAN bus used for Vehicle Functions0=CAN1, 1=CAN2 | ||
| 72 | ShuntCan | 0 | 1 | 0 | If Shunt used | CAN bus used for Shunt and or Contactors0=CAN1, 1=CAN2 | ||
| 73 | LimCan | 0 | 1 | 0 | If Charge Interface used | CAN bus used for Charging Interface0=CAN1, 1=CAN2 | ||
| 74 | ChargerCan | 0 | 1 | 1 | If Charger used | CAN bus used for Onboard Charger0=CAN1, 1=CAN2 | ||
| 89 | BMSCan | 0 | 1 | 1 | If BMS used | CAN bus used for BMS0=CAN1, 1=CAN2 | ||
| 96 | OBD2Can | 0 | 1 | 0 | CAN bus used for OBD2 comms0=CAN1, 1=CAN2 | |||
| 97 | CanMapCan | 0 | 1 | 0 | CAN bus used for CANmap parameters0=CAN1, 1=CAN2 | |||
| 107 | DCDCCan | 0 | 1 | 1 | If DCDC used | CAN bus used for DCDC0=CAN1, 1=CAN2 | ||
| 138 | HeaterCan | 0 | 1 | 1 | If CAN heater selected | CAN bus used for Heater0=CAN1, 1=CAN2 | ||
| 129 | MotActive | 0 | 3 | 0 | Toyota or Lexus Inverters only | Potnom to Torque Translation0=Mg1and2 - Both motors get same percentage request
1=Mg1 - Only use MG1 2=Mg2 - Only use MG2 3=BlendingMG2and1 - Use MG2 upto 50% Potnom then taper in MG1 | ||
| - Throttle | ||||||||
| 16 | potmin | dig | 0 | 4095 | 0 | Value of "pot" when pot isn't pressed at all | ||
| 17 | potmax | dig | 0 | 4095 | 4095 | Value of "pot" when pot is pushed all the way in | ||
| 18 | pot2min | dig | 0 | 4095 | 4095 | Value of "pot2" when regen pot is in 0 position | ||
| 19 | pot2max | dig | 0 | 4095 | 4095 | Value of "pot2" when regen pot is in full on position | ||
| 20 | regenrpm | rpm | 100 | 10000 | 1500 | |||
| 21 | regenendrpm | rpm | 100 | 10000 | 100 | |||
| 22 | regenmax | % | -30 | 0 | -10 | |||
| 23 | regenBrake | % | -30 | 0 | -10 | |||
| 24 | regenramp | %/10ms | 0.09 | 100 | 100 | Ramp speed when entering regen. E.g. when you set brkmax to -30% and regenramp to 1, it will take 300ms to arrive at brake force of -60% | ||
| 25 | potmode | 31 GND
32 Thr2 33 Thr1 34 +5v |
0 | 1 | 0 | 0=Single Channel
1=Dual Channel - Preferred setting | ||
| 26 | dirmode | 53 Rev
54 Fwd |
0 | 4 | 1 | Button
Switch ButtonReversed SwitchReversed DefaultForward | ||
| 27 | reversemotor | 0 | 1 | 0 | Off
On na | |||
| 28 | throtramp | %/10ms | 0.09 | 100 | 100 | The amount of allowed potnom change per %/10ms | ||
| 29 | throtramprpm | rpm | 0 | 20000 | 20000 | Above this motor rpm Throtramp is no longer applied | ||
| 30 | revlim | rpm | 0 | 20000 | 6000 | |||
| 31 | bmslimhigh | % | 0 | 100 | 50 | |||
| 32 | bmslimlow | % | -100 | 0 | -1 | |||
| 33 | udcmin | V | 0 | 1000 | 450 | Minimum battery voltage | ||
| 34 | udclim | V | 0 | 1000 | 520 | High voltage at which the PWM is shut down | ||
| 35 | idcmax | A | 0 | 5000 | 5000 | Maximum DC input current | ||
| 36 | idcmin | A | -5000 | 0 | -5000 | Maximum DC output current (regen) | ||
| 37 | tmphsmax | °C | 50 | 150 | 85 | |||
| 38 | tmpmmax | °C | 70 | 300 | 300 | |||
| 39 | throtmax | % | 0 | 100 | 100 | Throttle limit | ||
| 40 | throtmin | % | -100 | 0 | -100 | Throttle regen limit | ||
| 41 | throtmaxRev | % | 0 | 100 | 30 | |||
| 42 | throtdead | % | 0 | 50 | 10 | |||
| 43 | RegenBrakeLight | % | -100 | 0 | -15 | |||
| 44 | throtrpmfilt | rpm/10ms | 0.09 | 200 | 15 | |||
| - Gearbox Control | ||||||||
| 27 | Gear | 0 | 3 | 0 | Lexus GS450h only | Control of the GS450h gears0=LOW - always low gear
1=HIGH - always high gear 2=AUTO - Auto shifting between low and high based on speed 3=HIGHFWDLOWREV - reverse always low gear and forward always high gear | ||
| 28 | OilPump | % | 0 | 100 | 50 | Lexus GS450h only | Oil pump PWM duty cycle run setpoint | |
| - Cruise Control | ||||||||
| 29 | cruisestep | rpm | 1 | 1000 | 200 | |||
| 30 | cruiseramp | rpm/100ms | 1 | 1000 | 20 | |||
| 31 | regenlevel | 0 | 3 | 2 | ||||
| - Contactor Control | ||||||||
| 50 | udcsw | V | 0 | 1000 | 330 | |||
| 51 | cruiselight | 0 | 1 | 0 | Off
On na | |||
| 52 | errlights | 0 | 255 | 0 | Off
EPC engine | |||
| - Communication | ||||||||
| 53 | CAN3Speed | 25 L
26 H |
0 | 2 | 0 | k33.3
k500 k100 | ||
| - Charger Control | ||||||||
| 54 | BattCap | kWh | 0.09 | 250 | 22 | |||
| 55 | Voltspnt | V | 0 | 1000 | 395 | |||
| 56 | Pwrspnt | W | 0 | 12000 | 1500 | |||
| 57 | IdcTerm | A | 0 | 150 | 0 | |||
| 58 | CCS_ICmd | A | 0 | 150 | 0 | |||
| 59 | CCS_ILim | A | 0 | 350 | 100 | |||
| 60 | CCS_SOCLim | % | 0 | 100 | 80 | |||
| 61 | SOCFC | % | 0 | 100 | 50 | |||
| 62 | Chgctrl | 0 | 2 | 0 | Enable
Disable Timer | |||
| 63 | ChgAcVolt | Vac | 0 | 250 | 240 | |||
| 64 | ChgEff | % | 0 | 100 | 90 | |||
| - DC-DC Converter | ||||||||
| 65 | DCdc_Type | 0 | 1 | 0 | No DCDC
TeslaG2 | |||
| 66 | DCSetPnt | V | 9 | 15 | 14 | |||
| - Battery Management | ||||||||
| 67 | BMS_Mode | 0 | 3 | 0 | Off
SimpBMS TiDaisychainSingle TiDaisychainDual | |||
| 68 | BMS_Timeout | sec | 1 | 120 | 10 | |||
| 69 | BMS_VminLimit | V | 0 | 10 | 3 | |||
| 70 | BMS_VmaxLimit | V | 0 | 10 | 4.18 | |||
| 71 | BMS_TminLimit | °C | -100 | 100 | 5 | |||
| 72 | BMS_TmaxLimit | °C | -100 | 100 | 50 | |||
- Heater Module | ||||||||
| 73 | Heater | 0 | 2 | 0 | None
Ampera VW | |||
| 74 | Control | 0 | 2 | 0 | Disable
Enable Timer | |||
| 75 | HeatPwr | W | 0 | 6500 | 0 | |||
| 76 | HeatPercnt | % | 0 | 100 | 0 | |||
| - RTC Module | ||||||||
| 77 | Set_Day | 0 | 6 | 0 | ||||
| 78 | Set_Hour | Hours | 0 | 23 | 0 | |||
| 79 | Set_Min | Mins | 0 | 59 | 0 | |||
| 80 | Set_Sec | Secs | 0 | 59 | 0 | |||
| 81 | Chg_Hrs | Hours | 0 | 23 | 0 | |||
| 82 | Chg_Min | Mins | 0 | 59 | 0 | |||
| 83 | Chg_Dur | Mins | 0 | 600 | 0 | |||
| 84 | Pre_Hrs | Hours | 0 | 59 | 0 | |||
| 85 | Pre_Min | Mins | 0 | 59 | 0 | |||
| 86 | Pre_Dur | Mins | 0 | 60 | 0 | |||
| - General Purpose I/O | ||||||||
| 87 | Out1Func | 0 | 13 | 6 | ||||
| 88 | Out2Func | 4 | 0 | 13 | 7 | |||
| 89 | Out3Func | 3 | 0 | 13 | 3 | |||
| 90 | SL1Func | 39 | 0 | 13 | 0 | |||
| 91 | SL2Func | 38 | 0 | 13 | 0 | |||
| 92 | PWM1Func | 7 | 0 | 14 | 0 | |||
| 93 | PWM2Func | 6 | 0 | 14 | 4 | |||
| 94 | PWM3Func | 5 | 0 | 15 | 2 | |||
| 95 | GP12VInFunc | 50 | 0 | 13 | 12 | |||
| 96 | HVReqFunc | 51 | 0 | 13 | 11 | |||
| 97 | GPA1Func | 36 | 0 | 2 | 0 | Pot 1 *verification required | ||
| 98 | GPA2Func | 35 | 0 | 2 | 0 | Pot 2 *verification required | ||
| 99 | ppthresh | dig | 0 | 4095 | 2500 | |||
| 100 | BrkVacThresh | dig | 0 | 4095 | 2500 | |||
| 101 | BrkVacHyst | dig | 0 | 4095 | 2500 | |||
| - ISA Shunt Control | ||||||||
| 102 | IsaInit | 0 | 1 | 0 | Off
On na | |||
| 103 | Type | 0 | 2 | 0 | ISA
SBOX VAG | |||
| - PWM Control | ||||||||
| 104 | Tim3_Presc | 1 | 72000 | 719 | ||||
| 105 | Tim3_Period | 1 | 100000 | 7200 | ||||
| 106 | Tim3_1_OC | 1 | 100000 | 3600 | ||||
| 107 | Tim3_2_OC | 1 | 100000 | 3600 | ||||
| 108 | Tim3_3_OC | 1 | 100000 | 3600 | ||||
Spot Values
| Name | Description | Value | Unit | CAN Id | Position | Bits | Gain | Map to CAN | Notes | Additional Notes |
| version | 2.17.A | TX�RX | ||||||||
| opmode | Off | TX�RX | ||||||||
| chgtyp | Off | TX�RX | ||||||||
| lasterr | NONE | TX�RX | ||||||||
| status | PotPressed | TX�RX | ||||||||
| udc | 0 | V | TX�RX | |||||||
| udc2 | 0 | V | TX�RX | |||||||
| udc3 | 0 | V | TX�RX | |||||||
| deltaV | 0 | V | TX�RX | |||||||
| INVudc | 0 | V | TX�RX | |||||||
| power | 0 | kW | TX�RX | |||||||
| idc | 0 | A | TX�RX | |||||||
| KWh | 0 | kwh | TX�RX | |||||||
| AMPh | 0 | Ah | TX�RX | |||||||
| SOC | 100 | % | TX�RX | |||||||
| BMS_Vmin | 0 | V | TX�RX | |||||||
| BMS_Vmax | 0 | V | TX�RX | |||||||
| BMS_Tmin | 0 | °C | TX�RX | |||||||
| BMS_Tmax | 0 | °C | TX�RX | |||||||
| BMS_ChargeLim | 9999 | A | TX�RX | |||||||
| speed | 0 | rpm | TX�RX | |||||||
| Veh_Speed | 0 | kph | TX�RX | |||||||
| torque | 0 | dig | TX�RX | |||||||
| pot | 12 | dig | TX�RX | |||||||
| pot2 | 5 | dig | TX�RX | |||||||
| potbrake | 0 | dig | TX�RX | |||||||
| brakepressure | 0 | dig | TX�RX | |||||||
| potnom | 0 | % | TX�RX | |||||||
| dir | Neutral | TX�RX | ||||||||
| tmphs | 0 | °C | TX�RX | |||||||
| tmpm | 0 | °C | TX�RX | |||||||
| tmpaux | 0 | °C | TX�RX | |||||||
| uaux | 14.68 | V | TX�RX | |||||||
| canio | TX�RX | |||||||||
| FrontRearBal | 50 | % | TX�RX | |||||||
| cruisespeed | 0 | rpm | TX�RX | |||||||
| cruisestt | None | TX�RX | ||||||||
| din_cruise | Off | TX�RX | ||||||||
| din_start | Off | TX�RX | ||||||||
| din_brake | Off | TX�RX | ||||||||
| din_forward | Off | TX�RX | ||||||||
| din_reverse | Off | TX�RX | ||||||||
| din_bms | Off | TX�RX | ||||||||
| din_12Vgp | Off | TX�RX | ||||||||
| handbrk | Off | TX�RX | ||||||||
| Gear1 | Off | TX�RX | ||||||||
| Gear2 | Off | TX�RX | ||||||||
| Gear3 | Off | TX�RX | ||||||||
| T15Stat | Off | TX�RX | ||||||||
| InvStat | Off | TX�RX | ||||||||
| GearFB | LOW | TX�RX | ||||||||
| CableLim | 0 | A | TX�RX | |||||||
| PilotLim | 0 | A | TX�RX | |||||||
| PlugDet | Off | TX�RX | ||||||||
| PilotTyp | Absent | TX�RX | ||||||||
| CCS_I_Avail | 0 | A | TX�RX | |||||||
| CCS_V_Avail | 0 | V | TX�RX | |||||||
| CCS_I | 0 | A | TX�RX | |||||||
| CCS_Ireq | 0 | A | TX�RX | |||||||
| CCS_V | 0 | V | TX�RX | |||||||
| CCS_V_Min | 0 | V | TX�RX | |||||||
| CCS_V_Con | 0 | V | TX�RX | |||||||
| hvChg | Off | TX�RX | ||||||||
| CCS_COND | NotRdy | TX�RX | ||||||||
| CCS_State | 0 | s | TX�RX | |||||||
| CP_DOOR | CLOSED | TX�RX | ||||||||
| CCS_Contactor | Off | TX�RX | ||||||||
| Day | Sun | TX�RX | ||||||||
| Hour | 0 | H | TX�RX | |||||||
| Min | 3 | M | TX�RX | |||||||
| Sec | 25 | S | TX�RX | |||||||
| ChgT | 0 | M | TX�RX | |||||||
| HeatReq | Off | TX�RX | ||||||||
| U12V | 0 | V | TX�RX | |||||||
| I12V | 0 | A | TX�RX | |||||||
| ChgTemp | 0 | °C | TX�RX | |||||||
| AC_Volts | 0 | V | TX�RX | |||||||
| AC_Amps | 0 | A | TX�RX | |||||||
| canctr | 0 | dig | TX�RX | |||||||
| cpuload | 0.78 | % | TX�RX | |||||||
| PPVal | 0 | dig | TX�RX | |||||||
| BrkVacVal | 0 | dig | TX�RX | |||||||
| tmpheater | 0 | °C | TX�RX | |||||||
| udcheater | 0 | V | TX�RX | |||||||
| powerheater | 0 | W | TX�RX | |||||||
| serial | 43212553 | TX�RX |
https://github.com/damienmaguire/Stm32-vcu/blob/master/include/param_prj.h
