The LIM is also available new from BMW spare parts suppliers for € 240. If you acquire it new, it comes without firmware loaded, and it must be programmed first.
External links
> CAN logs
Connectors and Pinouts
Note: 15/5/24 Hirshman wouldn't send in uk without full vat number and form with lots of questions. However Auto-Click UK did seem to have all 16 pins. |
Audi 7M0 973 119 |
| 1B-2 | - | |
| 1B-10 | GND | Ground |
| 1B-11 | - | |
| 1B-12 | - | |
| 1B-13 | - | |
| 1B-14 | - | |
Some charge ports need additional 620 ohms to GND. |
Pilot (charge port) |
3B Pinout:
- N/A (for CHAdeMO only)
Wiring Diagram
Wiring notes
Current shunt
Fast charge contactor
Larger contactor control
Charge port
The Type 2 charge port used in Europe has no PP - PE resistor.
Make sure to match these if you want to use a different charge port. Some brands use different resistance values.
The CP communication for US Type 1 (1-phase) and EU Type 2 (3-phase) charge ports is similar, but the PP circuit is different.
Charge port lock
- Terminals: BMW 61131393724
Locks in other charge ports
- Peugeot: 2 motor pins, 2 feedback pins. Feedback is some sort of 2 pin semiconductor device, maybe hall effect. Feed 12V via 1k resistor, outputs about 10V when locked, 3V when open. A solution is needed for converting this to the LIM.
RGB charge indication light
Wake/sleep
- On plug insertion.
Programming a new LIM
If you purchase a new LIM, there is no configuration loaded; it is "virgin", and must be configured before use.
There are at least two ways to program a virgin BMW i3 LIM:
Programming LIM using E-Sys and a BDC/Key
Damien managed to program a brand new LIM with a i3 BDC (Body Domain Controller).
- Software:
- Hardware:
Programming LIM using Vector CAN and Fahrzeugauftrag (FA) file
- Hardware requirement: TBD
- Advantages/Disadvantages
Charge control
Contactor Test
- Fault set in 0x272 byte 2
celeron55's notes
Some detail of a tested 61 35 6 828 052 unit that may or may not be of interest to anyone:
- 0 = Open
- 1 = Closed (Assuming)
- 8 = Doing contactor test
CCS inlet temperature sensors
CAN communication
| Messages sent by LIM | ||||
LIM logs
Observations
LIM hardware
Physical dimensions
LIM versions
| Part No. | IEC 61851
J1772 (AC) |
Mini cooper SE |
now |
Power Limits
Chips on the LIM board
Charging protocols
Signaling circuit
AC charging
CCS DC charging
