ZombieVerter VCU
- Development thread
- GitHub repo
- fully built VCU boards
- partially-built VCU boards
Modern EV conversion projects often look to reuse salvaged parts from OEM vehicles, such as the motors, batteries and chargers.
The issue is that each part, and manufacturer, use different methods of control and communication. Even when the methods of control are decoded, you are left with having to develop some sort of VCU to run the devices. These devices often talk different "languages", such as CANBUS, LINBUS, sync serial, PWM, etc.
With a large array of inputs/outputs, control logic, and a web interface for configuration and data logging. The ZombieVerter is a powerful, flexible and customizable VCU well suited for EV conversions. It's also an open source project!
The ZombieVerter supports popular salvaged EV parts such as:
- Nissan leaf motor, PDM/OBC, and batteries
- Mitsubishi Outlander hybrid front & rear drive unit, and OBC (on board charger)
- Lexus GS450h and GS300h hybrid gearbox's
- CHAdeMO and CCS fast charging
- and more!
The ZombieVerter features the following:
Hardware:
- On-board WiFi
- 3x high side PWM drivers
- 5x low side outputs
- 3x CANbus interfaces
- LIN bus
- sync serial interface
- OBD-II interface
- etc.
Software:
- Web based user interface
- Contactor control
- Charger control
- Charge timer
- Motor (inverter) control
- Heater control
- Water pump control
- Coolant fan control
- Throttle mapping
- Motor regen
- Cruise control (?)
- BMS limits
- IVT shunt initialization
- Data logging and graphing
- etc.
This list is always growing and changing. Not everything is fully tested and verified.
- Chademo DC fast charging
- Lexus GS450h inverter / L110 gearbox via sync serial
- Lexus GS300h inverter / L210 gearbox via sync serial
- BMW E9x CAN support
- Mid-2000s VAG CAN support
- Subaru CAN support
- Opel Ampera / Chevy Volt 6.5kW cabin heater
- Mitsubishi Outlander motors/inverter
- EVS-Charge Port Controller
- Foccci CCS faster charger controller
- VAG/VW PTC water heater via LIN bus
- VAG/VW cabin heater via LIN bus
- Mitsubishi Outlander OBC (charger/DCDC)
- and more
Assembling the VCU
The enclosure kit options:
- Aptiv 56-pin connector
- Aptiv 56-pin header
Wiring
Each device requires different wiring setups, settings and power requirements.
Wiring the ZombieVerter with:
Power wiring
- Pin 55 to 12V- ground
- Pin 56 to 12V+ positive
- Pin 32 to ground pin on a 12V relay
- Relay positive pin to 12V+
- One of the relays switch pin to 12V+
- Leaf inverter enable pin
- Leaf PDM enable pin
- Mitsubisihi OBC enable pin
Contactor wiring
- ISA IVT shunt
- Nissan leaf inverter
- BMW S-BOX
- etc.
- Pin 31 for the negative contactor
- Pin 33 for the positive contactor
- Pin 34 for the pre-charge contactor
Throttle pedal wiring
- Pin 45 to throttle grounds
- Pin 46 to throttle channel 2
- Pin 47 to throttle channel 1
- Pin 48 to throttle positives
- Pin 15 to "on" switched input (key switched to "on")
- Pin 52 to "start" momentary input (momentary key switched "ignition")
Forward and Reverse
- Pin 53 reverse
- Pin 54 forward
Input/output pins
Low side Outputs.
- GP Out 3
- GP Out 2
- Trans SL2- (If not using the GS450H)
High side PWM.
- PWM 3
- PWM 2
- PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:
| Pin | IN/OUT/PWM | Function |
| ChaDemoAIw | OUTPUT | activates when Chademo charger handshake initiates |
| OBCEnable | OUTPUT | activates as part of the ExtCharger module |
| HeaterEnable | OUTPUT | activates only in run mode and when coolant pump is on* |
| RunIndication | OUTPUT | activates when zombie is in run mode |
| WarnIndication | OUTPUT | activates when a error occurs with the ZombieVerter |
| CoolantPump | OUTPUT | activates during precharge, usually used for coolant pumps |
| NegContactor | OUTPUT | activates when the negative contactor needs to be closed. ie precharge, run, charge mode, etc |
| BrakeLight | OUTPUT | activates when a set brake light on threshold value is met |
| ReverseLight | OUTPUT | activates when reverse direction is selected |
| CoolingFan | OUTPUT | activates when FanTemp setpoint is reached |
| HVActive | OUTPUT | activates when contactors are closed and VCU is in run or charge mode |
| BrakeVacPump | DIGITAL OUTPUT | activates when BrakeVacSensor threshold value is met |
| CpSpoof | PWM OUTPUT | used to spoof CP signal to OBC when using a charging interface such as FOCCCI or I3LIM |
| GS450Hpump | PWM OUTPUT | used to run GS450H oil pump |
| HeatReq | DIGITAL INPUT | |
| HVRequest | DIGITAL INPUT | starts precharge cycle and puts VCU into charge mode |
| ProxPilot | ANALOGUE INPUT | detects when charge cable is plugged in |
| BrakeVacSensor | ANALOGUE INPUT | vacuum sensor input, use for triggering BrakeVacPump DIGITAL OUTPUT |
| PWMTim3 |
Proximity Pilot
Initial start-up and testing
Powering up and connecting to the web interface
The following is required
- A fully built ZombieVerter VCU
- Two wires for power
- 12V power supply
- Computer/tablet for accessing the web interface
How to access the web interface
- Provide stable 12V power to pins 55, 56 on the ZombieVerter
- The on-board LED light "acty" should be now flashing
- Using your computer, connect to the ZombieVerters WIFI access point. SSID: "inverter" or "zom_vcu"
- Password is: inverter123
- In a web browser navigate to: 192.168.4.1
- The openinverter web interface should now load!
Configuration
*work in progress*
full list and overview of ZombieVerter Parameters and Spot Values
Basic parameters and spot values
Throttle
- potmin should be set just above where your off-throttle position is
- potmax just below the value seen at maximum travel
- Same for pot2min and pot2max
- throtmin is the minimum (most negative) allowed potnom at all times
- throtmax is the maximum (most positive) allowed potnom request in forward
- throtramp is how much potnom ramps up with the pedal pushed (potnom change per %/10ms)
- throtramprpm stops applying throtramp above a set motor rpm
- revlim is a rev limiter
Contactors
- ISA
- SBOX
- VAG
- LEAF
- udcmin is the minimum battery voltage derate
- udclim is maximum battery voltage derate
- udcsw is Voltage point at which precharge is considered finished, and the main contactor will close.
Forward/Reverse
input options:
- switch
- button
- switchReversed
- buttomReversed
Charger
Software
Initializing an ISA Shunt:
- Wire the ISA shunt to 12V+ and canbus input.
- Under shunt can in the web interface, select the canbus the shunt is connected to
- Hit save parameters to flash.
- Select "Init"
- Power cycle the vcu and shunt at same time (they should be on same 12V feed anyway).
- The shunt will initialize.
- Select ISAMode "normal"
- Save to flash again
- Reboot the VCU
page with ZombieVerter parameters and their value ranges, ZV pinmap etc.
Troubleshooting
Serial Connection
Recovering the ZombieVerter from a failed update
- Firstly, download the bootloader and latest ZombieVerter firmware from here [4] and here [5] as .hex files, this ensures you don't need to know the address of the file and avoids user error when flashing via STLink (I used a cheap STLink v2 clone without issue but it seems there is a mix of experiences with them).
- Connect the Clock (SWclk), Gnd and Data (SWDio) of your STLink to the ZombieVerter test points (near to the STM32 chip, they are labelled C, G, D) as well as 12V and Gnd to the ZombieVerter main power pins and ensure your STMCubeprogrammer is able to connect to it, I also disconnected the wifi board just incase.
- Remove your STLink from the ZombieVerter, connect the wifi board and check connectivity.
- Begin ZombieVerter-ing.
