BOM - Bill Of Material
Inverter Kit » Schematics and Instructions » Archived Instructions » BOM - Bill Of Material
These BOMs apply to all kits with the large sensor board that were shipped until January 2018. The kits thereafter contain a printed BOM.
The tables below list all parts that go on the PCB. The "ID" column references the part as designated on the part sheet.
Parts for main board version 1
| Part | ID | Value | Device |
| C1 | 1 | 22nF | C-EU025-024X044 |
| C2 | 2 | 1µ | C-EU025-024X044 |
| C3 | 2 | 1µ | C-EU025-024X044 |
| C4 | 2 | 1µ | C-EU025-024X044 |
| C5 | 2 | 1µ | C-EU025-024X044 |
| C6 | 2 | 1µ | C-EU025-024X044 |
| C7 | 2 | 1µ | C-EU025-024X044 |
| C8 | 2 | 1µ | C-EU025-024X044 |
| C9 | 2 | 1µ | C-EU025-024X044 |
| C10 | 3 | 10µ | CPOL-EUE2-4 |
| C11 | 2 | 1µ | C-EU025-024X044 |
| C12 | 2 | 1µ | C-EU025-024X044 |
| C13 | 4 | 1nF | C-EU025-024X044 |
| C14 | 4 | 1nF | C-EU025-024X044 |
| C15 | 2 | 1µ | C-EU025-024X044 |
| C16 | 2 | 1µ | C-EU025-024X044 |
| C17 | 2 | 1µ | C-EU025-024X044 |
| C18 | 5 | 0.1µ | C-EU050-024X044 |
| C19 | 5 | 0.1µ | C-EU050-024X044 |
| C20 | 6 | 220µ | CPOL-EUE2-4 |
| C21 | 7 | 680µ | CPOL-EUE2.5-5 |
| C23 | 2 | 1µ | C-EU025-024X044 |
| D1 | 9 | SB540E-G | |
| IC1 | 45 | LM2901 | |
| IC2 | 30 | 74F00 | |
| IC3 | MCP2562P | ||
| IC5 | 31 | LM2596TV | |
| JP1 | 39 | PINHD-2X13 | |
| JP2 | 39 | PINHD-2X13 | |
| JP3 | 37 | PINHD-2X7 | |
| 37 | Socket | ||
| JP4 | 36 | PINHD-2X8 | |
| 36 | Socket | ||
| JP5 | 38 | PINHD-2X13 | |
| 38 | Socket | ||
| JP6 | 35 | PINHD-1X4 | |
| JP7 | PINHD-1X3 | ||
| L1 | 14 | 50µH | L-EUTJ3-U1 |
| R1 | 18 | 500R | R-EU_0207/10 |
| R2 | 15 | 75R | R-EU_0207/10 |
| R3 | 16 | 1.2k/500R | R-EU_0207/10 (changed to 500R) |
| R4 | 17 | 120R/500R | R-EU_0207/10 (changed to 500R) |
| R5 | 18 | 500R | R-EU_0207/10 |
| R6 | 18 | 500R | R-EU_0207/10 |
| R7 | 19 | 10k | R-EU_0207/10 |
| R8 | 29 | 3.3k | R-EU_0207/10 |
| R9 | 19 | 10k | R-EU_0207/10 |
| R10 | 29 | 3.3k | R-EU_0207/10 |
| R14 | 19 | 10k | R-EU_0207/10 |
| R16 | 19 | 10k | R-EU_0207/10 |
| R17 | 19 | 10k | R-EU_0207/10 |
| R18 | 19 | 10k | R-EU_0207/10 |
| R19 | 19 | 10k | R-EU_0207/10 |
| R20 | na | R-EU_0207/10 | |
| R22 | 20 | 47k | R-EU_0207/10 |
| R23 | 20 | 47k | R-EU_0207/10 |
| R25 | 19 | 10k | R-EU_0207/10 |
| R26 | 19 | 10k | R-EU_0207/10 |
| RN1 | 25 | 4.7k | 8R-N |
| RN2 | 26 | 1.2k | RN08 |
| RN3 | 27 | 330R | E4R |
| T1 | 11 | BC547 | |
| T2 | 12 | ZTX1049A | |
| T3 | 12 | ZTX1049A | |
| T4 | 12 | ZTX1049A | |
| T5 | 12 | ZTX1049A | |
| T6 | 11 | BC547 |
R20 and JP7 are not populated!
Parts for main board version 2
| C1 | 4 | 1nF | |
| C2 | 4 | 1nF | |
| C3 | 4 | 1nF | |
| C5 | 4 | 1nF | |
| C7 | 4 | 1nF | |
| C8 | 3 | 10µ | |
| C10 | 2 | 1µ | C-EU025-024X044 |
| C13 | 2 | 1µ | C-EU025-024X044 |
| C14 | 2 | 1µ | C-EU025-024X044 |
| C18 | 2 | 1µ | C-EU025-024X044 |
| C19 | 2 | 1µ | C-EU025-024X044 |
| C20 | 2 | 1µ | C-EU025-024X044 |
| C22 | 5 | 0.1µ | |
| C23 | 2 | 1µ | |
| C24 | 6 | 220µ | CPOL-EUE2-4 |
| IC1 | 51 | ULN2003AN | |
| IC2 | 45 | LM2901 | |
| IC3 | 30 | SN74AS30N | |
| IC4 | 31 | LM2596 | |
| IC5 | 52 | MCP2562P | |
| J1 | J5MM | ||
| 37 | Socket | ||
| 36 | Socket | ||
| 38 | Socket | ||
| L1 | 14 | 50µH | |
| R1 | 18 | 500R | |
| R2 | 19 | 10k | R-EU_0207/10 |
| R3 | 18 | 500R | |
| R4 | 18 | 500R | |
| R5 | 19 | 10k | R-EU_0207/10 |
| R6 | 19 | 10k | R-EU_0207/10 |
| R7 | 15 | 120R | |
| R8 | 19 | 10k | R-EU_0207/10 |
| R9 | 29 | 3.3k | |
| R10 | 19 | 10k | R-EU_0207/10 |
| R11 | 19 | 10k | R-EU_0207/10 |
| R12 | 19 | 10k | R-EU_0207/10 |
| R13 | 29 | 3.3k | |
| R14 | 18 | 500R | |
| R15 | 18 | 500R | |
| R20 | 19 | 10k | R-EU_0207/10 |
| R21 | 19 | 10k | R-EU_0207/10 |
Parts sensor board (Revision 1 and 2):
| Part | Value | Device |
| C1 | 100nF | C-EU025-024X044 |
| C2 | 100µF | CPOL-EUE2-5 |
| C3* | 100nF | C-EU025-024X044 |
| C4** | 100nF | C-EU025-024X044 |
| C5** | 100nF | C-EU025-024X044 |
| IC1 | TLC274P/LM2902N | |
| R1 | 680k | R-EU_0207/10 |
| R2 | 680k | R-EU_0207/10 |
| R3 | 680k | R-EU_0207/10 |
| R4 | 680k | R-EU_0207/10 |
| R5 | 4.7k 1% | R-EU_0207/10 |
| R6 | 100k 1% | R-EU_0207/10 |
| R7 | 100k 1% | R-EU_0207/10 |
| R8 | 10k | R-EU_0207/10 |
| R9 | 100k 1% | R-EU_0207/10 |
| R10 | 100k 1% | R-EU_0207/10 |
| R11 | 10k | R-EU_0207/10 |
| R12 | 1.2k | R-EU_0207/10 |
| R13 | 3.3k 1% | R-EU_0207/10 |
| R14 | 4.7k 1% | R-EU_0207/10 |
| R15* | 4.7k 1% | R-EU_0207/10 |
| L1* | 10µH | L-EU |
| U$1 | TAMURA_L01Z_S05 | |
| U$2 | TAMURA_L01Z_S05 |
* = only on Rev 2 sensor board
** = Only populated when LEM current sensor is used (not standard)
Populate R1-R5 depending on your needs. The formular for the maximum DC voltage is
R1-R4 should be in the meg-Ohms region and R5 should be sized for the maximum desired DC voltage. The provided resistors allow a maximum voltage of 900V.
Parts sensor board (Revision 3):
| -UDC+ | 50 | Screw Clamp | |
| IL1_IL2_UDC_TMPHS_VCC | 35 | PINHD-1X8 | |
| C1 | 5 | 100nF | C-EU025-024X044 |
| C2 | 8 | 100µ | CPOL-EUE2-5 |
| C3 | 2 | 1µ* | C-EU025-024X044 |
| C4 | 100nF** | C-EU025-024X044 | |
| C5 | 100nF** | C-EU025-024X044 | |
| C6 | 2 | 1µ* | C-EU025-024X044 |
| C7 | 2 | 1µ* | C-EU025-024X044 |
| IC1 | 32 | LM2902N | |
| IC2 | 47 | * | ATTINY13DIP |
| PWS1 | 48 | * | ROE-0505S |
| OK1 | 49 | * | PC817 |
| R1 | 23 | 680k | R-EU_0207/10 |
| R3 | 23 | 680k | R-EU_0207/10 |
| R6 | 24 | 100k 1% | R-EU_0207/10 |
| R7 | 24 | 100k 1% | R-EU_0207/10 |
| R9 | 24 | 100k 1% | R-EU_0207/10 |
| R10 | 24 | 100k 1% | R-EU_0207/10 |
| R12 | 16 | 1.2k | R-EU_0207/10 |
| R13 | 29 | 3.3k 1% | R-EU_0207/10 |
| R14 | 28 | 4.7k 1% | R-EU_0207/10 |
| R15 | 18 | 500R* | R-EU_0207/10 |
| R16 | 18 | 500R* | R-EU_0207/10 |
| R17 | 19 | 10k* | R-EU_0207/10 |
| L1 | 13 | 10µH | L-EU |
| TMPHS | 35 | PINHD-1X2 | |
| U$1 | 41 | L06P800S05 | |
| U$2 | 41 | L06P800S05 |
Two extra 680k resistors are provided for high voltage applications (say, above 300V). Place them off board e.g. inline with the measurement leads. On the revision 2 boards they go on board.
* Only revision 3 board
** Only when using LEM HTFS current sensors
Parts Gate driver:
| -_BT_TP_+ | 35 | PINHD-1X4 | |
| C1 | 5 | 100n | C-EU050-025X075 |
| C2 | 5 | 100n | C-EU050-025X075 |
| C3 | 8 | 100µ | CPOL-EUE2,5-6E |
| C4 | 8 | 100µ | CPOL-EUE2,5-6E |
| C5 | 8 | 100µ | CPOL-EUE2,5-6E |
| C6 | 8 | 100µ | CPOL-EUE2,5-6E |
| C7 | 8 | 100µ | CPOL-EUE2.5-5 |
| C8 | 8 | 100µ | CPOL-EUE2.5-5 |
| D1 | 10 | P6KEXXC | |
| D2 | 10 | P6KEXXC | |
| DC1 | 40 | RH-051509D | |
| DC2 | 40 | RH-051509D | |
| IC1 | 33 | HCPL3120/Si8261BCC | |
| IC2 | 33 | HCPL3120/Si8261BCC | |
| R1 | 21 | 220R | R-EU_0207/10 |
| R2 | 21 | 220R | R-EU_0207/10 |
| R3 | 22 | 4.7R | R-EU_0309/12 |
| R4 | 19 | 10k | R-EU_0207/10 |
| R6 | 22 | 4.7R | R-EU_0309/12 |
