ZombieVerter VCU
Revision as of 23:42, 31 January 2025 by Bratitude (talk | contribs)
Zombiverter VCU board
An open-source EV conversions VCU (vehicle control unit) for controlling salvaged EV components!
There is a growing supply of OEM(original equipment manufacture) EV and hybrid parts; inverters, chargers, dc/dc converters, heaters, etc, requiring some control method in order to reuse them in a EV conversion.
After reverse engineering the communication signals for these devices, we need a control board to tell the device in question what todo. These devices often talk different "languages" some use CANBUS, LINBUS, sync serial, PWM, etc
hence the "zombieverter" VCU
The Zombieverter includes the following features:
hardware:
  • on board WIFI
  • 3x High side PWM drivers
  • 5x low side outputs
  • 3x CANbus interfaces
  • Linbus
  • sync serial interface
  • OBD-II interface
  • etc
Software:
  • web based user interface
  • contactor control
  • charger control
  • charge timer
  • motor(inverter) control
  • heater control
  • water pump control
  • coolant fan control
  • throttle mapping
  • motor regen
  • cruise control(?)
  • BMS limits
  • IVT shunt initialization
  • data logging and graphing
  • etc
Assembling the VCU
Looking to build a zombiverter VCU your self or your kit has missing hardware?
The enclosure kit options:
  2. Connector and pins[2]
  3. Prewired connector [3]
https://www.youtube.com/watch?v=iu9ffpkcxkQ
Wiring
Pin Out Diagrams
VCU pinout diagram
zombieverter pinout from https://github.com/damienmaguire/Stm32-vcu/blob/master/Hardware/Zombie/ZombieVerter_V1%20-%20Schematic.pdf
GS450H with zombieverter
Leaf stack with zombiverter
Tesla SDU with Zombieverter
Initial start-up and testing
Wifi Setup
Configuration Setup
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel [note this is the opposite for versions 1.06A to 1.11A ). Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
    • Note: Leaf inverter requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
leaf stack with zombiverter
Software
for programming a blank board see: zombiverter programing
web interface:
Initializing an ISA Shunt:
  1. wire the ISA shunt to 12v+ and canbus input.
  2. under shunt can in the web interface, select the canbus the shunt is connected to
  3. hit save parameters to flash.
  5. select "Init"
  6. hit save parameters to flash
  7. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway).
  8. The shunt will initialize.
  9. Select ISAMode "normal"
  10. save to flash again
  11. reboot the VCU
Low side Outputs.
  • GP Out 3
  • GP Out 2
  • TransSL2- (If not using the GS450H)
High side PWM.
  • PWM 3
  • PWM 2
  • PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:
  • ChaDemoAIw - OUTPUT - used as part of the Chademo charging protocol for the charge allow output to the charger.
  • OBCEnable - OUTPUT: activates as part of the ExtCharger module
  • HeaterEnable - OUTPUT: activates only in run mode and when coolant pump is on
  • RunIndication - OUTPUT: activates when zombie is in run mode
  • WarnIndication - OUTPUT
  • CoolantPump - OUTPUT: activates during precharge, usually used for coolant pumps
  • NegContactor - OUTPUT: activates during precharge for negative contactor
  • BrakeLight - OUTPUT: activates when brake input is detected
  • ReverseLight - OUTPUT: activates when direction is reverse
  • BrakeVacPump DIGITAL OUTPUT: when BrakeVacSensor below threshold this is turned on.
  • HeatReq - DIGITAL INPUT
  • HVRequest - DIGITAL INPUT - when used with ext charger setting will start precharge cycle and put VCU into charge mode.
  • ProxPilot - ANALOGUE INPUT - detect a charging cable plug in, requires external resistors, values depend on type 1 or type 2
  • BrakeVacSensor - ANALOGUE INPUT - read a vacuum sensor and turn on the BrakeVacPump DIGITAL OUTPUT
  • CoolingFan - OUTPUT: activates when FanTemp setpoint is reached
  • HVActive - OUTPUT: activates when contactors are closed and VCU is in run or charge mode
  • PWMTim3 -
  • CpSpoof - PWM OUTPUT: used to spoof CP signal to OBC if also using a charging interface such as FOCCCI or I3LIM
  • GS450Hpump - PWM OUTPUT: used to run GS450H oil pump
Proximity Pilot
Firmware
Troubleshooting
Serial Connection
If your ZV fails on the update and the Web User Interface is reporting "firmware: null" it's possibleyou'll need to reflash the firmware, bootloader via an STLink and/or delete any existing .bin and .Json files from the files section.
  1. Firstly, download the bootloader and latest zombieverter firmware from here [4] and here [5] as .hex files, this ensures you don't need to know the address of the file and avoids user error when flashing via STLink (I used a cheap STLink v2 clone without issue but it seems there is a mix of experiences with them).
  2. Download STMCubeProgrammer (other STM flashing softwares are available but the following instructions are based on what has worked for me).
  3. Upgrade the firmware on your STLink dongle using STMCubeProgrammer (I'm not sure if this is 100% necessary but seems prudent).
  4. Connect the Clock (SWclk), Gnd and Data (SWDio) of your STLink to the Zombieverter test points (near to the STM32 chip, they are labelled C, G, D) as well as 12V and Gnd to the Zombieverter main power pins and ensure your STMCubeprogrammer is able to connect to it, I also disconnected the wifi board just incase.
  5. Perform a "full chip erase", then reflash the latest bootloader and firmware hex files.
  6. Remove your STLink from the zombieverter, connect the wifi board and check connectivity.
  7. Begin Zombieverter-ing.
