ZombieVerter VCU
An open-source EV conversions VCU (vehicle control unit) for controlling salvaged EV components!
- Development thread
- github repo
- fully built VCU boards
- partially-built VCU boards
There is a growing supply of OEM(original equipment manufacture) EV and hybrid parts; inverters, chargers, dc/dc converters, heaters, etc, requiring some control method in order to reuse them in a EV conversion.
After reverse engineering the communication signals for these devices, we need a control board to tell the device in question what todo. These devices often talk different "languages" some use CANBUS, LINBUS, sync serial, PWM, etc
hence the "zombieverter" VCU
The Zombieverter includes the following features:
hardware:
- on board WIFI
- 3x High side PWM drivers
- 5x low side outputs
- 3x CANbus interfaces
- Linbus
- sync serial interface
- OBD-II interface
- etc
Software:
- web based user interface
- contactor control
- charger control
- charge timer
- motor(inverter) control
- heater control
- water pump control
- coolant fan control
- throttle mapping
- motor regen
- cruise control(?)
- BMS limits
- IVT shunt initialization
- data logging and graphing
- etc
- Chademo dc fast charging
- BMW E9x CAN support
- Mid-2000s VAG CAN support
- subaru CAN support
- EVS-Charge Port Controller
- VAG/VW cabin heater via lin
Assembling the VCU
Looking to build a zombiverter VCU your self or your kit has missing hardware?
The enclosure kit options:
- aptive 56pin connector
- aptive 56pin header
https://www.youtube.com/watch?v=iu9ffpkcxkQ
Wiring
Pin Out Diagrams
Leaf stack with zombiverter
Tesla SDU with Zombieverter
Notes:
- This drawing is intended to show the minimum components and connections needed for Zombieverter control of an OI SDU via Can bus. Adapting power and Can bus connections for other OI inverters should function in the same manner, but this needs verification.
- All power connections must be fuse protected. Fuses are not shown for simplification.
- The following observations were made using Zombieverter firmware 2.20A and SDU firmware 5.35R:
- The Zombieverter does not enable inverter power prior to entering PreCharge mode. An external device other than the inverter is required to supply the udc measurement for switch to Run mode. This function is supported by the shunt and BMS options available in the Zombieverter parameters.
- A third device must be on the Can bus with the Zombieverter and Inverter.
- Requirements 1. and 2. are satisfied in the drawing by the IVT shunt.
- All devices except the Zombieverter are shown as powered by the ignition switch. Some devices may need to move to permanent 12V supply to support other functions, such as charging.
- An inverter power relay is required for Zombieverter control.
- Can mapping to pass data and commands from the Zombieverter to the inverter is hard coded in the firmware for both devices. Manual mapping is required for the inverter to transmit data to the Zombieverter. The Zombieverter is hard coded to receive this data. The following values need to be manually mapped in the inverter. Note: mapping uses hex address values, multipliers may need to change to provide correct values (confirm in Zombieverter spot values), inverter udc gets mapped to inv udc in the Zombieverter.
| Spot Value | Hex Address | Offset | # Bits | Multiplier | Map |
| speed | 400 | 0 | 16 | 1 | Tx |
| tmphs | 410 | 0 | 16 | 10 | Tx |
| udc | 420 | 0 | 16 | 10 | Tx |
| opmode | 430 | 0 | 8 | 1 | Tx |
Initial start-up and testing
Wifi Setup
Configuration Setup
Software
for programming a blank board see: zombiverter programing
web interface:
Initializing an ISA Shunt:
- wire the ISA shunt to 12v+ and canbus input.
- under shunt can in the web interface, select the canbus the shunt is connected to
- hit save parameters to flash.
- select "Init"
- Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway).
- The shunt will initialize.
- Select ISAMode "normal"
- save to flash again
- reboot the VCU
Low side Outputs.
- GP Out 3
- GP Out 2
High side PWM.
- PWM 3
- PWM 2
- PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:
- WarnIndication - OUTPUT
- HeatReq - DIGITAL INPUT
- PWMTim3 -
Proximity Pilot
Firmware
Troubleshooting
Serial Connection
If your ZV fails on the update and the Web User Interface is reporting "firmware: null" it's possibleyou'll need to reflash the firmware, bootloader via an STLink and/or delete any existing .bin and .Json files from the files section.
- Begin Zombieverter-ing.
