ZombieVerter VCU
Revision as of 16:33, 17 July 2024 by Tom91 (talk | contribs) (Clean up supported hardware 2x mention)
KINDLY NOTE:
  • A fully tested V1a kit is now (Nov2022) available for general sale here. The boards are now shipping with the Wemos wifi module and all parts will be included in the kit. The Olimex header is still there for those who may prefer that option. See this post for the Wemos wifi module mounting location.
Support is available via this section on the forum
There is a growing supply of OEM inverters, chargers, dc/dc converters, heaters, etc, requiring some control method in order to use them in a EV conversion. Instead of replacing the original logic board in these devices (with some devices it is physically impossible to do so), a vehicle control unit (vcu) which talks in its native communication protocol is a much more elegant solution. With a vcu, we can simply tell these logic boards what we want in a language they can understand, and they will do it. As far as they are concerned, they are still installed in the OEM vehicle they left the factory in.
What is not elegant is having a series of bespoke vcu boards for each device. Instead, a master vcu which can handle a variety of different communication protocols(thus a variety of devices) was born; the zombiVerter !
The zombieVerter is available via evbmw's web shop https://www.evbmw.com/index.php/evbmw-webshop/vcu-boards/zombie-vcu
Based around the original design of the open inverter platform, the zombieVerter consists of 2 main parts:
  • a web interface
  • a communication protocol
With onboard wifi, you can access the open inverter web interface (http://192.168.4.1/) to:
  • set up/calibrate the different devices(inverter, charger, etc) connected to the vcu.
  • tune control parameters (throttle, regen, charge speed, charge time, BMS limits, etc)
  • log info
  • graph and plot live data (rpm, amps, charge rate, etc)
  • update firmware
  • pwm
  • canbus
  • linbus
  • sync serial
  • etc
features of the zombiverter offers:
  • Throttle mapping
  • Precharge and contactor control
  • coolant pump control
  • Temp derating
  • BMS limits
  • for/rev/neutral control
  • Graphing and monitoring
  • Firmware updates via the web interface
  • Cruise control
    • traction control*
  • Fuel gauge driver
  • heater controller
  • charge timer
  • custom pwm out puts
  • etc
Location of remaining parts
Parts to be fitted to ZombieVerter VCU
Name Part Numer Alternative Part Number
CONN1
IC10 MCP25625T
IC14 TJA1020 MCP2004
IC19 NCV7356
IC20 TJA1055T
IC21, IC22 AD5160
IC27, IC28, IC29 FAN3122 MIC4422YM (according to https://openinverter.org/forum/viewtopic.php?p=72827#p72827)
NOTE : R50 will need to be changed to 1k and C45 to 1n in order for LIN to work properly. This will be amended on further builds. So if you have a board ordered before 14/03/24 this change is required.
The enclosure kit links
ZombieVerter VCU V1 Part 3
<youtube>https://youtu.be/rUaYSWmtsCI</youtube>
Installation
Pin Out Diagram
Leaf stack with zombiverter
VCU pinout diagram
List of connections to system components (GS450 application)
leaf stack to zombie
Initial start-up and testing
Wifi Setup
Configuration Setup
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel [note this is the opposite for versions 1.06A to 1.11A ). Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
    • Note: Leaf inverter requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
leaf stack with zombiverter
Software
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
That recursively pulls in copies of libopeninv, etc and tracks them...   Hence your file-path should look like
./Stm32-vcu/libopeninv/src/
Software update
Initializing an ISA Shunt
Under Comms in the web interface, there is now an ISAMode option. By default its in "Normal" (Off on Rev 2). If you want to initialize a new shunt, connect it up, power on the shunt and vcu, select "Init" (On on Rev 2), hit save parameters to flash. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway). The shunt will initialize. Select ISAMode "normal" (Off on Rev 2), save to flash again and reboot again. The shunt should now be up and running. If the shunt doesn't initialise correctly, separate the shunt and VCU supplies and power cycle the VCU two or three seconds after the shunt power is cycled. This has fixed an initialise issue for a number of ISA shunts and possibly requires a VCU code fix that delays the initialising for a few seconds to allow the shunt to power up.
Low side Outputs.
  • GP Out 3
  • GP Out 2
  • TransSL2- (If not using the GS450H)
High side PWM.
  • PWM 3
  • PWM 2
  • PWM 1
Pin functions:
  • ChaDemoAIw - OUTPUT - used as part of the Chademo charging protocol for the charge allow output to the charger.
  • OBCEnable - OUTPUT: activates as part of the ExtCharger module
  • HeaterEnable - OUTPUT: activates only in run mode and when coolant pump is on
  • RunIndication - OUTPUT: activates when zombie is in run mode
  • WarnIndication - OUTPUT
  • CoolantPump - OUTPUT: activates during precharge, usually used for coolant pumps
  • NegContactor - OUTPUT: activates during precharge for negative contactor
  • BrakeLight - OUTPUT: activates when brake input is detected
  • ReverseLight - OUTPUT: activates when direction is reverse
  • BrakeVacPump DIGITAL OUTPUT: when BrakeVacSensor below threshold this is turned on.
  • HeatReq - DIGITAL INPUT
  • HVRequest - DIGITAL INPUT
  • ProxPilot - ANALOGUE INPUT - detect a charging cable plug in, requires external resistors, values depend on type 1 or type 2
  • BrakeVacSensor - ANALOGUE INPUT - read a vacuum sensor and turn on the BrakeVacPump DIGITAL OUTPUT
Proximity Pilot
Troubleshooting
Serial Connection
