Tesla Model S GEN1 Charger
Charger Connectors
- AC (Input)
- DC (Output)
- Tesla: In Dual OBC vehicles, the second ("Slave") OBC does not utilize 1) the Fast Charge Contactors connectors; or 2) the HVIL Loop connector, as the first ("Master") OBC performs those functions.
Wire size * |
Telsa
Wire Color * |
| 2 ** | Charge Port: nozzle lock | "InsertEN out" | 20 AWG (0.5mm²) | YL |
| 6 ** | Fast Charge CAN | "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" | 20 AWG (0.5mm²) | RD-WH |
| 8 | Drive inhibit | "Prox out", signal to DU to inhibit drive | 22 AWG (0.35mm²) | OR-PU |
| 12 ** | "BMS_12V_in" | "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables DCFC contactors?) | 18 AWG (0.75mm²) | RD-GY |
** = Not used on RAV4 EV.
AC Input Connector
DC Output Connector
The Molex datasheet strongly recommends the use of NylogMetalocalypseel 760G dielectric grease on this terminal if it will be exposed to vibration and/or thermal cycling[16].
HVIL Connector (J5)
Common Issues
- Two 50A fuses protect the AC input legs: one fuse for Neutral, one for Hot/L1. These fuses are a common failure point. The cause of their failure is not known. Some units have had their fuses fail more than once. Typically, only one fails at a time. The OEM fuse is Ferraz Shawmut (Mersen) 50A 500VAC fuse, part No. A50P50-4[17]. Some people have found that after replacing a single failed fuse, the other one will later fail; it is surmised that this is possibly a genuine instance of a fuse weakening over time/use, so the generic recommendation is to replace them both. Typical pricing for the Ferraz Shawmut units is USD$50-100 each (Mar2023); Eaton Bussmann (Cooper) FWH-50B is said[18] to be an equivalent, and can be had for under $30 (Mar2023)[19]
Important Considerations
Output Voltage Range
| HEED DAMIEN'S WARNING:[21]
(regarding the GEN2 OBC, which may or may not apply to the GEN1) |
CAN
WIP
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
