Tesla Model S/X GEN2 Charger
The Tesla GEN2 charger is a single/three phase 10kW AC charger that was fitted in the Model S from 2012 until it was replaced in the 2016 'facelift' model with GEN3.
Important Considerations
Output Voltage Range
| HEED DAMIEN'S WARNING:[1] |
Supported Tesla Part Numbers (TPN)
It has been found that early revision units will not work with the OI control boards.[2]
TPNs to avoid:
- 1014963-05-B and 1014963-05-C
TPNs tested and known good:
- 1014963-00-E/F/J/K/L
- 1014963-00-G is likely also good, just wasn't mentioned by name in the referenced thread
Cooling
The direction of flow in the cooling plate does not seem to matter.[3]
Replacement Control Boards
Charger Connections
| A1 | A2 | A3 | A4 | A5 | B1 | B2 | B3 | B4 | B5 | B6 | |
| OUT2 - AC present | D1 - enable | 12V supply | CANH | Control Pilot | |||||||
| A6 | A7 | A8 | A9 | A10 | B7 | B8 | B9 | B10 | B11 | B12 | |
| OUT1 - HV enable | D2 - 3p | GND | CANL | Proximity |
Connector part numbers
- housing: 044441-2006
- pins: 043375-3001 (18-20AWG), 043375-0001 (14-16AWG)
- housing: 10-way 19418-0014, 12-way 19418-0026
- pins: 33012-2002 (18-20AWG), 33012-2001 (14-16AWG)
Programming
You'll need a ST-LINK/V2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
- ST-LINK programming utility: https://www.st.com/en/development-tools/stsw-link004.html
- stm32_loader.hex https://openinverter.org/forum/viewtopic.php?f=7&t=1119
Two options:
- Charger_gen2_v5.hex https://github.com/damienmaguire/Tesla-Charger/tree/master/V5/Software/Binary
- openinverter style firmware https://openinverter.org/forum/viewtopic.php?t=1323 (only available via patreon for next few weeks)
External CAN bus
Revision V4aB3 does not need this modification. If you do NOT use the external CAN bus on that version remember to close the solder jumper next to R1 under the WiFi module.
If the charger is the first/last device on your CAN bus there is nothing else to do. If it is somewhere in the middle you have to remove the bus termination resistor R1.
Before doing this be aware that all internal CAN traffic is also seen on the external CAN bus. The following IDs are already used and mustn't used by any other device on the bus:
| ID | Direction | Byte 0 | Byte 1 | Byte 2 | Byte 3 | Byte 4 | Byte 5 | Byte 6 | Byte 7 |
| 0x102 | Receive by charger | DC voltage limit MSB | DC voltage limit LSB | DC current set point | ==1 enable charging | SoC | |||
| 0x108 | Transmit by charger | Version=0 | Max DC voltage MSB | Max DC voltage LSB | Max DC current | ||||
| 0x109 | Transmit by charger | Version=0 | DC voltage MSB | DC voltage LSB | DC current | 0 when off, 5 when charging |
openinverter style charger firmware
- Support for the standard open inverter web interface
- Parameter handling as known from the inverter firmware (see picture)
- Spot value handling like inverter including plotting, gauges, and logging
- Over the air update like inverter
- DC current control
- CAN control as described above
By default all charger kits will have SSID : charger PASSWORD : charger123
Note: Its recommend that you change it. Nobody wants to drive and have some joker with a phone finding this information and accessing your charger.
Registration
Commercial firmware usage manual
We will go over all of them.
idclim
iaclim
idcspnt
chargerena
udcspnt
udclim
timelim
inputype
- Type2: Specifies one or more modules are operated on ONE common phase of a Type-2 EVSE. The limits imposed by cablelim and evselim (pilot signal) are distributed equally over the enabled modules. For example if you enable all 3 modules, the cable allows 32A but the EVSE only allows 16A, every module will run at 16/3=5.3A. Charging will start automatically as soon as proximity and a valid pilot signal is detected.
- Type2-3P: Specifies each module is connected to a different phase of a Type-2 EVSE. The limits imposed by cablelim and evselim are allowed for each module.
- Type-2Auto: relies on input D2 to indicate that 3 phase is present (from external relay), to allow charging on either single or three phase automatically.
- Type1: Like Type2 but cablelim is always assumed 40A.
- Manual: Specifies one or more modules are operated on ONE common phase, power is distributed like in Type2 mode. Charging starts as soon as the enable pin "D1" goes high. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
- Manual-3P: Specifies that each module is connected to a different phase of 3-phase outlet. Each module is allowed iaclim AC current. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
cancontrol
idckp/idcki
pin
Additional Resources
The Tesla Project : 10 Kw Gen 2 Charger
The Tesla Project : Charger Progress
The Tesla Project : 10kW Charger Charging
The Tesla Project : More Charger Hacking
The Tesla Project : Charger 10kw Run
Common Issues
- The Tesla chargers are very sensitive to grounding. The case MUST be connected to vehicle 12v ground AND evse earth/ground when charging. [1]
- If you do NOT use the external CAN bus on that version remember to close the solder jumper next to R1 under the WiFi module.
- People had problems with unreliable connectivity between ESP8266 & the charger board [2]
- Firmware 1.09 and 1.10 can lose the CAN map, making the logic board go silent, reset instructions here: [3]
