ZombieVerter VCU
Zombiverter VCU board
Modern EV conversion projects often look to reuse salvaged parts from OEM vehicles, such as the motors, batteries and chargers.
The issue is that each part, and manufacture, use different methods of control and communication. Even when the methods of control are decoded, you are left with having to develop some sort of VCU to run the devices. These devices often talk different "languages", such as CANBUS, LINBUS, sync serial, PWM, etc
introducing: the "Zombieverter" VCU
a general purpose EV conversion VCU.
With a large array of inputs/outputs, control logic, and a web interface for configuration and data logging. The Zombieverter is a powerful, flexible and customizable VCU well suited for EV conversions. its also an open source project!
The Zombieverter supports popular salvaged EV parts such as:
  • Nissan leaf motor, PDM/OBC, and batteries
  • Mitsubishi outlander hybrid rear drive unit, and OBC (on board charger)
  • Lexus gs450H and gs300H hybrid gearbox's
  • tesla model S dcdc converter
  • chademo and ccs fast charging
  • etc
The Zombieverter features the following:
hardware:
  • on board WIFI
  • 3x High side PWM drivers
  • 5x low side outputs
  • 3x CANbus interfaces
  • Linbus
  • sync serial interface
  • OBD-II interface
  • etc
Software:
  • web based user interface
  • contactor control
  • charger control
  • charge timer
  • motor(inverter) control
  • heater control
  • water pump control
  • coolant fan control
  • throttle mapping
  • motor regen
  • cruise control(?)
  • BMS limits
  • IVT shunt initialization
  • data logging and graphing
  • etc
Assembling the VCU
Looking to build a zombiverter VCU your self or your kit has missing hardware?
The enclosure kit options:
  2. Connector and pins[2]
  3. Prewired connector [3]
https://www.youtube.com/watch?v=iu9ffpkcxkQ
Wiring
VCU pinout diagram
zombieverter pinout from https://github.com/damienmaguire/Stm32-vcu/blob/master/Hardware/Zombie/ZombieVerter_V1%20-%20Schematic.pdf
each device requires different wiring setups, settings and power requirements.
wiring the zombieverter with:
Input/output pins:
The Zombieverter has a number of selectable input/output pins that can be used for a number of functions. These pins are:
Low side Outputs.
  • GP Out 3
  • GP Out 2
  • TransSL2- (If not using the GS450H)
High side PWM.
  • PWM 3
  • PWM 2
  • PWM 1
These are high side 12v outputs, usually for controlling gauges or auxiliary items than need a pwm signals.
Ground Input pins
PB1
PB2
PB3
Pin functions:
  • ChaDemoAIw - OUTPUT - activates when Chademo charger handshake initiates
  • OBCEnable - OUTPUT: activates as part of the ExtCharger module
  • HeaterEnable - OUTPUT: activates only in run mode and when coolant pump is on*
  • RunIndication - OUTPUT: activates when zombie is in run mode
  • WarnIndication - OUTPUT: activates when a error occurs with the zombieverter
  • CoolantPump - OUTPUT: activates during precharge, usually used for coolant pumps
  • NegContactor - OUTPUT: activates when the negative contactor needs to be closed. ie precharge, run, charge mode, etc
  • BrakeLight - OUTPUT: activates when a set brake light on threshold value is met
  • ReverseLight - OUTPUT: activates when reverse direction is selected
  • CoolingFan - OUTPUT: activates when FanTemp setpoint is reached
  • HVActive - OUTPUT: activates when contactors are closed and VCU is in run or charge mode
  • BrakeVacPump DIGITAL OUTPUT: activates when BrakeVacSensor threshold value is met
  • CpSpoof - PWM OUTPUT: used to spoof CP signal to OBC when using a charging interface such as FOCCCI or I3LIM
  • GS450Hpump - PWM OUTPUT: used to run GS450H oil pump
  • HeatReq - DIGITAL INPUT
  • HVRequest - DIGITAL INPUT - starts precharge cycle and puts VCU into charge mode
  • ProxPilot - ANALOGUE INPUT - detects when charge cable is plugged in
  • BrakeVacSensor - ANALOGUE INPUT - vacuum sensor input, use for triggering BrakeVacPump DIGITAL OUTPUT
  • PWMTim3 -
Proximity Pilot
Initial start-up and testing
once the
Configuration Setup
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel [note this is the opposite for versions 1.06A to 1.11A ). Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
    • Note: Leaf inverter requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
leaf stack with zombiverter
Software
for programming a blank board see: zombiverter programing
web interface:
Initializing an ISA Shunt:
  1. wire the ISA shunt to 12v+ and canbus input.
  2. under shunt can in the web interface, select the canbus the shunt is connected to
  3. hit save parameters to flash.
  5. select "Init"
  6. hit save parameters to flash
  7. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway).
  8. The shunt will initialize.
  9. Select ISAMode "normal"
  10. save to flash again
  11. reboot the VCU
Troubleshooting
Serial Connection
if the zombieverter fails in the middle of a software update and the Web User Interface is reporting "firmware: null" it's possible you'll need to re-flash the firmware, and bootloader via an STLink.
  1. Firstly, download the bootloader and latest zombieverter firmware from here [4] and here [5] as .hex files, this ensures you don't need to know the address of the file and avoids user error when flashing via STLink (I used a cheap STLink v2 clone without issue but it seems there is a mix of experiences with them).
  2. Download STMCubeProgrammer (other STM flashing softwares are available but the following instructions are based on what has worked for me).
  3. Upgrade the firmware on your STLink dongle using STMCubeProgrammer (I'm not sure if this is 100% necessary but seems prudent).
  4. Connect the Clock (SWclk), Gnd and Data (SWDio) of your STLink to the Zombieverter test points (near to the STM32 chip, they are labelled C, G, D) as well as 12V and Gnd to the Zombieverter main power pins and ensure your STMCubeprogrammer is able to connect to it, I also disconnected the wifi board just incase.
  5. Perform a "full chip erase", then reflash the latest bootloader and firmware hex files.
  6. Remove your STLink from the zombieverter, connect the wifi board and check connectivity.
  7. Begin Zombieverter-ing.
