Tesla Model S GEN1 Charger
Charger Connectors
- AC (Input)
- DC (Output)
- Tesla: In Dual OBC vehicles, the second ("Slave") OBC does not utilize 1) the Fast Charge Contactors connectors; or 2) the HVIL Loop connector, as the first ("Master") OBC performs those functions.
Wire size * |
Telsa
Wire Color * |
| 2 ** | Charge Port: nozzle lock | "InsertEN out" | 20 AWG (0.5mm²) | YL |
| 6 ** | Fast Charge CAN | "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" | 20 AWG (0.5mm²) | RD-WH |
| 8 | Drive inhibit | "Prox out", signal to DU to inhibit drive | 22 AWG (0.35mm²) | OR-PU |
| 12 ** | "BMS_12V_in" | "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables DCFC contactors?) | 18 AWG (0.75mm²) | RD-GY |
** = Not used on RAV4 EV.
AC Input Connector
DC Output Connector
HVIL Connector (J5)
Common Issues
Grounding
Fuses
Testing the circuit resistance of the AC input from the J1772 charge port end (on Toyota RAV4 EV or MB B250e) or the Tesla power conductors (on Model S) should also provide some differential numbers if a leg is open due to an open fuse. The power pin inputs are wired straight into those fuses in the OBC.
Tesla: testing the Tesla OBC (from the charge port large pins) or RAV4 EV (from J1772 large AC pins), with good fuses:
- Either AC input to chassis ground = ~2.6M Ω
- AC-to-AC input = ~241k Ω
If one fuse is open, two of those numbers will be substantially higher.
Important Considerations
Output Voltage Range
| HEED DAMIEN'S WARNING:[21]
(regarding the GEN2 OBC, which may or may not apply to the GEN1) |
CAN
WIP
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
