Tesla Model S GEN1 Charger
Charger Connectors
- AC (Input)
- DC (Output)
- Tesla: In Dual OBC vehicles, the second ("Slave") OBC does not utilize 1) the Fast Charge Contactors connectors; or 2) the HVIL Loop connector, as the first ("Master") OBC performs those functions.
Wire size * |
Telsa
Wire Color * |
6 | Fast Charge CAN | "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" | 20 AWG (0.5mm²) | RD-WH |
12 | "BMS_12V_in" | "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables charger?) | 18 AWG (0.75mm²) | RD-GY |
AC Input Connector
DC Output Connector
HVIL Connector (J5)
Common Issues
- Two 50A fuses protect the AC input legs: one fuse for Neutral, one for Hot/L1. These fuses are a common failure point. The cause of their failure is not known. Some units have had their fuses fail more than once. Typically, only one fails at a time. The OEM fuse is Ferraz Shawmut 50A 500VAC fuse, part No. A50P50-4[16]. Some people have found that after replacing a single failed fuse, the other one will later fail; it is surmised that this is possibly a genuine instance of a fuse weakening over time/use, so the generic recommendation is to replace them both. Typical pricing is USD$50-100 each (Mar2023).
Important Considerations
Output Voltage Range
HEED DAMIEN'S WARNING:[17] |
Charger Dimensions:
- 19-13/16" L x 13-7/16" W x 4-7/16" H (503mm L x 341mm W x 113mm H)
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
