Tesla Model S GEN1 Charger
Charger Connectors
- AC (Input)
- DC (Output)
- the HVIL Loop connector
Wire size * |
Telsa
Wire Color * |
8 | EVSE-Prox (PP) OUT | PP signal from EVSE to Drive Unit. Marked "Prox out" on Tesla's documentation, this was thought to be a "inhibit drive" signal, but testing has been inconclusive/negative for that function so far. | 22 AWG (0.35mm²) | OR-PU |
11 | EVSE-Prox (PP) IN | PP signal from EVSE to OBC | 20 AWG (0.5mm²) | OR |
** = Not used on RAV4 EV.
AC Input Connector
DC Output Connector
HVIL Connector (J5)
Common Issues
Grounding
Fuses
Important Considerations
Output Voltage Range
HEED DAMIEN'S WARNING:[21]
(regarding the GEN2 OBC, which may or may not apply to the GEN1) |
CAN
WIP
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
