when I saw a guy locking up a 7 Eleven convenience store,
hey buddy what do you think you're doing I asked.
Locking up! the man exclaimed
But the sign says Open 24 Hours.
Yeah, but not in a row, he retorted
Hmmm, that got me to thinkin', could I do an EV conversion in [ahem] 30 days?
So here are the RULES so far for the EV Conversion (and we get to make these up as we go along):
- Rule # 1. Keep it Simple!
- Rule # 2. When in doubt, refer to Rule # 1.
$1,200 - Battery Pack
$450 - Zombieverter VCU
$250 - Motor
$200 - Charger/DC-DC Converter
$100 - misc, fuses, relays, hoses, terminals
$90 - Inverter
$80 - GPS Speedometer
$80 - Single Din WiFi Radio Dispaly
$50 - partial Inverter Wire Harness
$30 - Throttle Pedal
$30 - Coolant Pump
$25 - partial Resolver Wire Harness
$2,585 - TOTAL
COMPONENTS
- Motor: the air cooled 70 hp 2009 Toyota Highlander AWD rear motor MGR
- Battery: BMW 530e hybrid 12 kWh Info on BMW hybrid battery packs?
- Contactor Box: OEM BMW Safety Box aka sBox again to start, then maybe roll my own DIY box if the sBox can't handle a higher voltage
- Inverter: Toyota Camry or Gen 3 Prius with the OEM internal logic board
- Charger:Mitsubishi Outlander DCDC OBC at least to start, then maybe upgrade to the Ding Dong 550 volt one, more on that later
VEHICLE REQUIREMENTS:
- Must be my birth year.
- Can't be red, I hate red cars! (a shiet !)
- Should have IRS
- Less Means More - would love to use a single box All-In-One solution, Gen3 Prius Inverter, Controller (via internal logic board swap), DC-DC Converter, and even have it act as a charger [emphasis on Pipe Dream]
- Even Less Means Even More - no power steering, no power brakes, no air conditioning, no heater, no problems
- Range: 50 miles
- Tope Speed: [think captain slow] 60 MPH if that, this will be a city putt around car
- come up with a no welding required bolt in kit, fully reversible conversion (for that first human in history to actually attempt to reverse an EV
Conversion) - air cooled components in an air cooled people's car
