The LIM is also available new from BMW spare parts suppliers for € 240. If you get it new, it comes without firmware loaded, and it must be programmed first.
External links
Forum discussion
> CAN logs
> I3 LIM CAN dbc1
BMW I3 HV components
LIM Connector Kit
LIM Compatible Contactors
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1[1] / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector (?Hirschmann 805-587-545?)[2]Auto-Click UK Part link has Pin 13 through 16 blocked. Received a Mercedes Part from them instead of BMW using this part number. Please check the part for proper compatibility
Audi 7M0 973 119
TE 1-967616-1[3][4]
X Rubber Seal 1-967067-1[6]
LIM Connectors and Pin Numbering
1B Pinout:
Pin # Function Description
1B-2 -
1B-6 CAN_H Powertrain CAN
1B-7 CAN_L Powertrain CAN
1B-8 IGN Wake up signal input and output +12V (ignition, contact 15)
1B-9 VCC Constant Power +12V
1B-10 GND Ground
1B-11 -
1B-12 -
1B-13 -
1B-14 -
1B-15 CHARGE_E Goes to KLE. Guessing this is charge enable or drive interlock signal? (Not necessary)
2B Pinout:
Pin # Function Description (BMW) Description (MINI)[8]
2B-1 CP Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! Pilot (charge port)
2B-2 PP Proximity (charge port) Proximity (charge port)
2B-3 Jumper Connected to Pin 4 PE / GND
2B-4 Jumper Connected to Pin 3 Connected to Pin 5
2B-5 PE / GND Ground (charge port earth) Connected to Pin 4
2B-6 - US CCS1 version connected to 2B-2 N/C (TBD if used for US CCS1)
3B Pinout:
- N/A (for CHAdeMO only)
4B Pinout:
4B-1 POS_CONT+ Positive HV Contactor Control          (Contactor coil resistance must be ~15 ohms)
4B-2 NEG_CONT+ Negative HV Contactor Control        (Contactor coil resistance must be ~15 ohms)
4B-3 POS_CONT- Positive HV Contactor Control          (Contactor coil resistance must be ~15 ohms)
4B-4 NEG_CONT- Negative HV Contactor Control        (Contactor coil resistance must be ~15 ohms)
4B-5 U_HV_DC Charge Port DC Voltage (current input 3-20mA?)(1.42V for 0V HV, linear to 4.8V for 500V HV)[9]
4B-10 COV_MOT- Charge Port Cover Motor (Not necessary)
4B-12 COV_FB Charge Port Cover Feedback (connect to GND to simulate open cover[10])(To be left floating for contactors weld test)
Wiring Diagram
BMW i3 DCFC CCS factory wiring (simplified) (1-phase version, probably US)
Wiring notes
This board needs to produce an isolated 3-20mA current signal (or: 1.42V for 0V HV, linear to 4.8V for 500V HV)[12] from the high voltage DC voltage.
BMW i3 LIM voltage sense board by EVcreate
Fast charge contactor
Larger contactor control
Charge port
DUOSIDA / MIDA CCS(2) inlet
Make sure to match these if you want to use a different charge port. Some brands use different resistance values.
Charge port lock
Locks in other charge ports
  • Peugeot: 2 motor pins, 2 feedback pins. Feedback is some sort of 2 pin semiconductor device, maybe hall effect. Feed 12V via 1k resistor, outputs about 10V when locked, 3V when open. A solution is needed for converting this to the LIM.
RGB charge indication light
RGB LED
Wake/sleep
  • On plug insertion.
Programming a new LIM
If you purchase a new LIM, there is no configuration loaded; it is "virgin", and must be configured before use.
There are at least two ways to program a virgin BMW i3 LIM:
  • Use BMW E-Sys software in combination with a salvaged Body Domain Controller, and possibly requiring a matching physical key[15];
  • Use a Vector CAN (or similar) and a Fahrzeugauftrag (FA) file to edit and write information to the LIM without E-Sys[16]
Programming LIM using E-Sys and a BDC/Key
Damien managed to program a brand new LIM with a i3 BDC (Body Domain Controller).
Programming LIM using Vector CAN and Fahrzeugauftrag (FA) file
  • Hardware requirement: TBD
    • Vector CAN (can other hardware be used?)
  • Software requirement: BMW E-sys v3.34 (tested[18])
  • Advantages/Disadvantages
Charge control
Contactor Test
  2. Charge Port door state closed (charge door feedback pin 4B-12 floating)
    1. charge door feedback is set to locked in 0x272 byte 2
    1. Fault set in 0x272 byte 2
  4. Ignition in 0x12F byte 2 needs to toggle from OFF 0x88 to ON 0x8a
celeron55's notes
Some detail of a tested 61 35 6 828 052 unit that may or may not be of interest to anyone:
  1. The intention is to make the LIM do this test at vehicle power up. In Zombie terms that means when going into the MOD_RUN state.
  2. The LIM will do the contactor test if it sees for a duration of 3 seconds that:
    1. The charge door is closed according to feedback (feedback line at 12V). 0x272 byte 2 bits 0 and 1. On Zombie that's the CP_DOOR parameter.
    2. The inlet voltage sensor is giving a low enough value (the limit is 60V according to above). 0x3B4 byte 7. On Zombie that's the CCS_V_Con parameter.
    3. The CAN ignition bit in 0x12F byte 2 was OFF earlier. (0x8a=ON, 0x86=OFF)
    4. The CAN ignition bit in 0x12F byte 2 is ON currently. On Zombie this gets set when opmode==MOD_RUN. Charging is disabled in opmode==MOD_RUN, so afterwards before charging it needs to be changed yet again to another value.
  3. What happens in the contactor test is that the LIM closes the contactors for a bit and then opens them. If the LIM likes what it sees, this clears the 0x272 byte 2 contactor bits to 0. On Zombie that's the CCS_Contactor parameter.
  4. On the bench, the LIM doesn't seem to care if the inlet voltage sensor doesn't sense a voltage during the test. However on the bench it was impossible to tell whether it would actually proceed to charge or not.
  5. The meaning of the CCS_Contactor values are as follows. Values other than 0 and !=0 may not be visible in UIs, but due to the nature of how the value is read from CAN, it can have other values than 0 and 1.
    1. 0 = Open
    2. 1 = Closed (Assuming)
    3. 8 = Doing contactor test
    4. 24 = Inlet voltage high / udc low
    5. 28 = Waiting for ignition cycle
CCS inlet temperature sensors
CAN communication
0x112 BMS msg. VCU or BMS 10ms needed
0x2FC Charge flap control VCU 100ms (4s) needed (constant values work)
0x03C Vehicle status VCU 200ms (constant values)
0x1A1 Vehicle speed VCU 20ms (constant values)
0x2A0 Central locking VCU 200ms (4s) (constant values)
0x397 OBD VCU 200ms (constant values) not needed
0x3F9 Engine info VCU 1000ms (constant values)
0x3A0 Vehicle condition VCU 200ms (constant values)
0x330 Range info VCU 200ms (constant values) not needed
0x512 Network management edme VCU 200ms (constant values) not needed
0x560 Network management kombi VCU 200ms (constant values) not needed
0x328 Counter VCU 1s needed
0x3E8 OBD reset VCU 1s (constant values)
0x380 Vin VCU not needed
Messages sent by LIM
0x29E CCS charger specs LIM
0x337 Inlet lock status LIM
LIM logs
Observations
LIM hardware
Physical dimensions
LIM versions
LIM versions
Part No. IEC 61851
J1772 (AC)
61 35 9 346 827 x x BMW i3
61 35 9 346 820 x x BMW i3
61 35 6 828 052 BMW i3 Aug 2019[19]
Mini cooper SE
now
Power Limits
Chips on the LIM board
components
Charging protocols
Signaling circuit
AC charging
CCS DC charging
