Nissan Leaf Motors
Revision as of 09:11, 8 February 2023 by Scrappyjoe (talk | contribs) (EM57: add rough dimensions along with source attribution)
The Nissan EM motor is an electrical motor manufactured by Nissan Motors.
its used in a variety of vehicles, mainly the nissan leaf
It is an 3-phase AC synchronous power electric motor, utilizing interior neodymium permanent magnets.
BRAT INDUSTRIES has motor couplers and adapter plates available here https://bratindustries.net/ and has opensourced a adapter plate for the em57 motor, which can be found here.
open inverter replacement board for gen2 inverter: Nissan Leaf Gen2 Board
zombieVerter VCU can bus controller: ZombieVerter VCU
As with all opensource projects, please give credit and links to original developers
EM61
EM61 Dimensions
em61 motor tear down
The em61 motor was used in the first generation nissan leaf. It's a stand alone ipmsm motor, with a theoretical peak power output of a 250kw+.
Regarded as nissans "r&d" motor, being the presents of stronger rare earth magnets. resulting in a slightly higher torque output efficiency than the gen2 em57 motor.
In the stock OEM leaf, the motor was battery and inverter limited to 80kw and made 280Nm of peak torque.
The EM61 made its debut in 2010. It was used only in the first generation Nissan Leaf (ZE0 2010-2012).
EM57
em57 motor
This link leads to maintenance document for resolver wiring
https://openinverter.org/forum/viewtopic.php?p=47467#p47467
The em57 utilizes a stacking architecture for the power electrons, compared to the isolated nature of the em61 motor.
Nissan has continued to use the em57 motor through multiple generation of vehicles, resulting in mechanically plug and play OEM inverter upgrades.
Inverters currently compatible with the em57 motor:
  • gen 2 leaf 80kw inverter
  • gen 3 leaf 110kw inverter
  • gen 3 leaf 160kw inverter
  • Nissan Leaf (AZE0 2013-2017)
  • Nissan e-NV200 (2014-Present)
  • Nissan Leaf (ZE1 40kWh, 2018-Present)
  • Nissan Leaf (ZE1 62kWh, 2019-Present)
  • Nissan Note e-Power (2017-Present)
  • Nissan Serena e-Power (2018-Present)
EM57 Dimensions
The below photographs show the rough dimensions of the EM57. These photos were taken from https://www.diyelectriccar.com/threads/nissan-leaf-cad-files.203894/#post-1064439, which has more detailed information.
EM57 motor. Source: https://www.diyelectriccar.com/threads/nissan-leaf-cad-files.203894/#post-1064439
EM57 motor side. Source: https://www.diyelectriccar.com/threads/nissan-leaf-cad-files.203894/#post-1064439
Plugs and connectors
The resolver plug is Yazaki 7283-8855-30 (https://www.auto-click.co.uk/7283-8855-30?search=7283-8855-30)
EM47
The EM47 motor released in 2020 with the refreshed Nissan Note. It is only used in Nissan's e-POWER lineup. It features a 40% size reduction and 30% weight reduction
  • Nissan Note e-Power (2020-Present)
