ZombieVerter VCU
Revision as of 17:59, 10 January 2023 by AdrianB (talk | contribs) (Description and link to forum support updated)
KINDLY NOTE:
  • A fully tested V1a kit is now (Nov2022) available for general sale here. The boards are now shipping with the Wemos wifi module and all parts will be included in the kit. The Olimex header is still there for those who may prefer that option. See this post for the Wemos wifi module mounting location.
Support is available via this section on the forum
There's a growing supply of OEM inverters, chargers, dc/dc converters, heaters, etc, requiring some control method in order to use them in a ev conversion. Instead of replacing the original logic board in these devices (some devices its physically impossible to do so), a vcu which talks in its native communication protocol is a much more elegant solution. What is not elegant is having a series of bespoke vcu boards for each device, instead a master vcu which can handle a variety of different communication protocols(thus a variety of devices) was born; the zombiVerter !
available via evbmw's web shop https://www.evbmw.com/index.php/evbmw-webshop/vcu-boards/zombie-vcu
based around the original design of the open inverter platform, the zombieVerter consists of 2 main parts:
  • the web interface
  • the communication protocol
With onboard wifi, you can access the open inverter web interface to:
  • set up/calibrate the different devices(inverter, charger, etc) connected to the vcu.
  • tune control parameters (throttle, regen, charge speed, charge time, BMS limits, etc)
  • log info
  • graph and plot live data (rpm, amps, charge rate, etc)
  • update firmware
  • pwm
  • canbus
  • linbus
  • sync serial
  • flexray
  • etc
What we have as of now is the openinverter wrapper with things like :
  • Throttle cal and mapping,
  • Precharge and contactor control,
  • Temp derating,
  • BMS limits,
  • for/rev/neutral control,
  • Graphing and monitoring,
  • Firmware updates via the web interface,
  • Cruise control,
  • Fuel gauge driver,
  • etc
Location of remaining parts
Parts to be fitted to ZombieVerter VCU
Name Part Numer Alternative Part Number
CONN1
IC10 MCP25625T
IC14 TJA1020 MCP2004
IC19 NCV7356
IC20 TJA1055T
IC21, IC22 AD5160
IC27, IC28, IC29 FAN3122
The enclosure kit links
  • Enclosure Kit with Header, connector and pins[1]
  • Connector and pins[2]
  • Prewired connector with 3M leads (limited colors which will not match standard wire colouring conventions)[3]
ZombieVerter VCU V1 Part 3
<youtube>https://youtu.be/rUaYSWmtsCI</youtube>
Installation
Pin Out Diagram
VCU pinout diagram
List of connections to system components (GS450 application)
Initial start-up and testing
Wifi Setup
NOTE: Recent units have a new wifi module that isn't automatically assigning an IP via DHCP. See this thread for details, and if you can help resolve the issue. Until then, you need to manually assign an IP of 192.168.4.2 (anything other than 192.168.14.1 on the 192.168.4.0/24 subnet) to your device.
Configuration Setup
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just below where your off-throttle position is, and potmax just above the value seen at maximum travel [note this used to be the opposite prior to version 1.06A). Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
  • Note: Leaf VCU requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
Software
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
That recursively pulls in copies of libopeninv, etc and tracks them...   Hence your file-path should look like
./Stm32-vcu/libopeninv/src/
Software update
Initializing an ISA Shunt
Supported OEM Hardware
  • Nissan Leaf Gen1/2/3 inverter via CAN
  • Nissan Leaf Gen2 PDM (Charger and DCDC)
  • CCS DC fast charge via BMW i3 LIM - currently type 2 only, type 1 under development
  • Lexus GS450h inverter / gearbox via sync serial
  • Toyota Prius/Yaris/Auris Gen 3 inverters via sync serial
  • Mid-2000s VAG CAN support
  • Opel Ampera / Chevy Volt 6.5kw cabin heater
Troubleshooting
Serial Connection
