I want a cheap EV Conversion
Revision as of 11:59, 8 December 2022 by 4markowen (talk | contribs)
Audi A2 with Prius Inverter
VW Beetle 2003 EV conversion
Rule number One
Don't buy a rust bucket. This is the quickest route to making a cheap conversion into an expensive one. Where you'll spend time and resources on fixing additional parts of the car and are not able to focus time and effort on the actual conversion process.
Components
You will want Integrated components, that fulfill multiple functions in your build at the same time:
- cheap motor & inverter, ideally combined units (Toyota Prius Gen2 Inverter, )
- cheap batteries, this will be your biggest expense (Nissan Leaf BMS, BMW i3, repurposed hybrid batteries?)
- smaller battery packs can be compensated for by enabling rapid charging
- DC/DC converter; this replaces the alternator to keep the 12v systems running in your car. (Mitsubishi Outlander DCDC OBC )
- charger ( integrated into existing units, such as Nissan Leaf PDM, Mitsubishi Outlander charger & DCDC, Prius Inverter & charger )
Legalities
If you are on a budget, make sure your locality allows what you are trying to do:
UK UK2 United Kingdom
The Netherlands
If you are looking for a performant ev conversion check the sister page.
