Toyota Prius Gen2 Inverter
- See this video for a more brief explanation of the above noted disassembled Gen2 HV System Operation: https://www.youtube.com/watch?v=UxuqHcUbSQ0
Replacement Controllers
Pin # | Designation | Description | Wire Color
Wire Color
(Harness Side) |
1 | vacant | |||
2 | GIVA | MG1 Phase Current V | LightGreen | White - Cable 1 |
3 | GIVB | MG1 Phase Current V | Purple-Red | Black - Cable 1 |
4 | GUU | MG1 PWM U - Speed Signal Wave | Blue | Black - Cable 2 |
5 | GVU | MG1 PWM V - Speed Signal Wave | Blue-Red | Green - Cable 2 |
6 | GWU | MG1 PWM W - Speed Signal Wave | Yellow | Yellow - Cable 2 |
7 | MIVA | MG2 Phase Current V | LightGreen-Black | Green - Cable 3 |
8 | MIVB | MG2 Phase Current V | Purple-Yellow | White - Cable 3 |
9 | MUU | MG2 PWM U - Speed Signal Wave | Blue-Black | Black - Cable 4 |
10 | MVU | MG2 PWM V - Speed Signal Wave | Blue-Yellow | White - Cable 4 |
11 | MWU | MG2 PWM W - Speed Signal Wave | Yellow-Black | Red - Cable 4 |
12 | VH | Inverter Capacitor Voltage | Purple | Yellow - Cable 3 |
13 | CPWM | Boost converter PWM switch signal | Blue | Black - Cable 5 |
14 | CT | Boost converter temperature sensor | Green-Red | Red - Cable 5 |
15 | VL | Boost converter input voltage | Purple-White | Yellow - Cable 5 |
16 | GINV | Inverter Ground | Black-White | Yellow - Cable 4 |
17 | vacant | |||
18 | GIWA | MG1 Phase Current W | Grey | Red - Cable 1 |
19 | GIWB | MG1 Phase Current W | Grey-Black | Green - Cable 1 |
20 | GSDN | MG1 Shutdown | Brown-Black | Red - Cable 2 |
21 | GIVT | MG1 Inverter Temperature | Green-Black | White - Cable 2 |
22 | GFIV | MG1 Inverter Fail | White-Grey | Grey |
23 | MIWA | MG2 Phase Current W | Grey-Green | Red - Cable 3 |
24 | MIWB | MG2 Phase Current W | Grey-Red | Black - Cable 3 |
25 | MSDN | MG2 Shutdown | Brown | Green - Cable 4 |
26 | MIVT | MG2 Inverter Temperature | Green | Light Blue - Cable 4 |
27 | MFIV | MG2 Inverter Fail | White | Green |
28 | OVH | Overvoltage | Pink | Brown |
29 | CSDN | Boost converter shutdown signal | Brown-White | White - Cable 5 |
30 | FCV | Boost converter fail signal | White-Red | White |
31 | OVL | Boost converter over voltage signal | Pink-Blue | Black |
32 | GCNV | Boost converter ground | Black-Red | Green - Cable 5 |
(Article continues below)
DC-DC Converter
1 | IGCT | 12v+ | Blue |
2 | ID1 | Not Needed | Purple |
3 | S | B+ (opt) | White |
4 | NODD | 0-5v+ | Ppl/Gld |
5 | VLO | Not Needed | Blue |
6 | Vacant |
A/C Inverter
The onboard A/C inverter is powered by the high voltage traction battery to supply 3 phase power to the A/C pump. It's controlled by a propriety SPI like 12v interface.
The 6-pin "I11" connector terminal positions and inverter side colours:
1 | GND | GND | Black/White |
2 | TOECU(ITE) | Data from inverter | Green/White |
3 | TOINV(ETI) | Data to inverter | Yellow/White |
4 | CLK | serial clock | Brown/White |
5 | STB | chip select | Blue/White |
6 | IG | 12v+ | Red/White |
The CLK and ITE signals comes alive when supplying12V to IG and >40V to the main DC Power supply inlet and pull-up/pull-down connected to them(CLK and ITE). For the inverter to start you need higher voltage >200V to main DC Power supply inlet, STB to GND and send appropriate 10 byte messages to the inverter on ETI. For more information, logs, how to connect and example code to control See https://github.com/hakanrolsson/Prius-Gen2-A-C-compressor-inverter
Buck/Boost Converter
The inverter also has an onboard buck/boost converter that - when needed - can boost the ~200v battery pack up to 600v to send to the motors, and buck down high voltage generated by the motors in regen mode to recharge the batteries. See 'Charging' section below for how the buck/boost converter has been used for AC charging. See link below for another method of controlling the buck/boost converter.
Inverter Cooling
Wiring
Connector | Male | Female |
C5 | 90980-10988 | 90980-10987 |
B+ (DC-DC output) | 90980-11963 | |
32-pin connector | TE 1318747-1 (& 1123343-1 for pins) | |
28-pin connector (on inverter logic board) | TE 1565380-1 (& 1123343-1 for pins) |
Charging
Relevant Parameters
Charge mode:Buck
Chargecur: 1.5
Chargekp 20
Chargeki: 10
Chargeflt 2 dig
Relevant Pins
- CSDN (pin 29 on inverter)
- Controls DC relay switch.
Physical setup
Process
Offgrid AC Use
See: https://openinverter.org/forum/viewtopic.php?p=22886
See: https://github.com/jsphuebner/stm32-island
External Links
https://www.youtube.com/watch?v=Xl87abBl9-A - Physical destructive teardown of the Gen2 inverter.
