2020 Leaf Motor: Which connector is which?
CasaDelGato
Post by CasaDelGato »
I'm planning on using a Zombieverter with a used 110kW Leaf motor, 2020. PDU Model 292C0 5SA1B (A3 ?), EM57 316386Z
On the https://openinverter.org/wiki/Leaf_stac ... ombiverter page, it shows several connector pinouts for the Leaf Motor - which I can't see how they match with what I see on my motor.
I can identify the 12v +/-, J1772, Pack, CHaDemo connectors.
I don't see how the other connectors correspond to F13, F14, and F18. ( 2 big round ones on my motor, and several small ones.)
I can't seem to find any source for a 2020 Leaf Service manual either.
Zieg
Has thanked: 152 times
Been thanked: 146 times
Re: 2020 Leaf Motor: Which connector is which?
Post by Zieg »
F14 is the resolver connector on the motor can, near the coolant lines.
The others are different because the wiki is showing connectors for a gen2 system and you have gen3. The round one connecting to the inverter is the equivalent to the rectangular one (F13) on the wiki.
CasaDelGato
Ahh, fun. Anyone have the pinouts for a Gen3 set of connectors?
Has thanked: 213 times
Been thanked: 173 times
Post by jrbe »
https://photos.app.goo.gl/mfgp9rkYvGKA6XPQ9
Make sure you're looking at the connections from the right direction.
Delete the .txt at the end, it's a pdf.
2021_nissan_leaf_Network_diagram-1.pdf.txt
(19.57 MiB) Downloaded 496 times
CasaDelGato
Thanks! That will be very helpful.
Marat
Been thanked: 11 times
Post by Marat »
The pictures WiKi show Leaf 80 kW, you have Leaf 110 kW, it has different connectors and different can traffic.
Has thanked: 207 times
Been thanked: 563 times
Marat wrote: Mon Nov 25, 2024 7:53 am different can traffic.
All generations work with the Zombie Verter.
Here is an example of the 160kw, same connector also gen 3 working with Zombie Verter. viewtopic.php?t=4322
m.art.y
Has thanked: 35 times
Been thanked: 32 times
Post by m.art.y »
tom91 wrote: Mon Nov 25, 2024 11:12 am All generations work with the Zombie Verter.
Tom, I've tested what I call a gen4 Leaf stack (2023 onwards with a Toyota PDM) with a Zombieverter and there was no response of any kind. I took a CAN log, could you take a look?
viewtopic.php?p=74590&hilit=Gen4+leaf+stack#p74590
Marat
Post by Marat »
The problem is not with the engine but with the operation of the PDM (this is a DC-DC block, charging, and the absence of a full CHaDemo)
In LEAF 110-160KW CHaDemo is implemented in the VCM block, in the PDM there are only power relays and a CHaDemo voltage sensor.
Marat wrote: Mon Nov 25, 2024 12:13 pm The problem is not with the engine but with the operation of the PDM (this is a DC-DC block, charging, and the absence of a full CHaDemo)
Okay then please make a topic on this will all relevant info, this way this can be looked at how to support it within the zombie code base.
