I just bought a Mitsubishi Outlander charger. - Now What?
Has thanked: 493 times
Been thanked: 909 times
Re: I just bought a Mitsubishi Outlander charger. - Now What?
I also bought the Mitsubishi Outlander Battery Charging Cable part number 9482 A150
and no that's not what I paid for it, and yes, eBay is loosing it's mind and getting worse every upgrade
Gentlemen I could really appreciate your help in identifying the mystery 3 prong "extra" cable in this Medusa like listing
royhen99
Has thanked: 22 times
Been thanked: 130 times
Post by royhen99 »
That's the rear inverter to motor cable.
That price is very cheap for both cables. Was this listing for just one of the cables and did you get the right one?
Has thanked: 131 times
Been thanked: 330 times
Now you are truly on the path to put in Outlander motor and inverter :).
arber333 wrote: Fri Mar 15, 2024 7:43 pm Now you are truly on the path to put in Outlander motor and inverter :).
shhhh don't tell anyone but I am leaning that way for Conversion #3
royhen99 wrote: Fri Mar 15, 2024 4:42 pm That's the rear inverter to motor cable.
I should get it today, it appears after it left UK it decided to tour California. I seem to live between a major receiving center and the post office distribution center on the other side of town, so they literally drive within 1 mile of my house from one place to the other in the morning, only to turn around and deliver it to my house later that evening
Sat, Mar 16 Out For Delivery Today West Sacramento, CA
Sat, Mar 16 Arrived at Facility West Sacramento, CA
Fri, Mar 15 Arrived at Facility Oakland, CA
Fri, Mar 15 Arrived at Facility Visalia, CA
Thu, Mar 14 We have your package Riverside, CA
Fri, Mar 8 Customs Cleared {UNKNOWN PLACE}, State 0000
Thu, Mar 7 Flight Touch Down LAX, CA 90045
Mitsubishi Outlander Charger Cables
Time to see if I can get charging working on the work bench
so first, time to figure out the low voltage control wiring, and this guy seems to know what he's talking about
DIY EV Part 26 - Outlander PHEV OBC Charger Pt1 Three reasons Why I Failed Before.
Mr. Ali Bro
Gregski wrote: Mon Jun 10, 2024 2:51 pm so first, time to figure out the low voltage control wiring, and this guy seems to know what he's talking about
The LV control connector is this one Sumitomo 6189-1092
And can be get here....
https://www.aliexpress.com/item/1005005 ... ry_from%3A
Or here
https://www.auto-click.co.uk/6189-1092
arber333 wrote: Mon Jun 10, 2024 3:54 pm The LV control connector is this one Sumitomo 6189-1092
thank you so much, using only two colors for a dozen or so pins, my kinda people, lol
Has thanked: 342 times
Been thanked: 1484 times
DIY then https://de.aliexpress.com/item/1005004366836123.html (I'm using that variant - less splicing)
Gregski wrote: Mon Jun 10, 2024 4:04 pm thank you so much, using only two colors for a dozen or so pins, my kinda people, lol
Dont you smirk at me, i crimp my own pins 8-).
all set up for charging, fingers crossed
Mitsubishi Outlander Charger ZombieVerter VCU Working
zippy500
Has thanked: 69 times
Post by zippy500 »
looking good, so does the Zombie control the charge control then ?
the ZombieVerter VCU controls (talks to) the Mitsubishi Outlander on CAN Bus 2 so it uses these two pins on the connector
let's take a look at the ZombieVerter VCU software, and the settings we need to configure for the Outlander Charger
we start under Parameters (pronounced: "Settings") under the General Setup section
first we need to select Out_lander using the pulldown menu next to the chargemodes parameter
chargemodes: Out_lander
next we just need to verify (no need changing anything) that the ChargerCan pulldown menu is on it's default setting of CAN2
ChargerCan: CAN2
then we move on to the Charger Control section
so let's go over these one by one
Alibro
Has thanked: 362 times
Been thanked: 217 times
Post by Alibro »
Mr. Ali Bro
Don't listen to anything that guy says. He's a MORON!!!
dammogreen
Post by dammogreen »
Can someone give a quick summary of the advantages of the Outlander charger vs others? I notices Damien also chose one..with combined with a leaf stack. TIA
Has thanked: 199 times
Been thanked: 524 times
dammogreen wrote: Wed Feb 19, 2025 5:29 pm Can someone give a quick summary of the advantages of the Outlander charger vs others?
Thanks for the super open ended question. Answer is what ever you need and can get works
Scrappyjoe
Has thanked: 40 times
Been thanked: 22 times
Post by Scrappyjoe »
1. Cheap
2. Both a charger and a DCDC in a compact package
3. Supported by the Zombieverter
Scrappyjoe wrote: Wed Feb 19, 2025 8:04 pm 1. Cheap
4. Good 2nd hand CAN reporting on charging voltage, current, temperature... To compare to your BMS reference or to use as its own control reference.
5. Did i mention its quite cheap?
EDIT: Temp reporting is T[°C] + 40. So charger actually reports [hex] - 40 . Normaly primary and secondary temp are a bit different.
