I just bought a Mitsubishi Outlander charger. - Now What?
- Gregski
- Has thanked: 500 times
- Been thanked: 946 times
Re: I just bought a Mitsubishi Outlander charger. - Now What?
I also bought the Mitsubishi Outlander Battery Charging Cable part number 9482 A150
and no that's not what I paid for it, and yes, eBay is loosing it's mind and getting worse every upgrade
Gentlemen I could really appreciate your help in identifying the mystery 3 prong "extra" cable in this Medusa like listing
- Has thanked: 22 times
- Been thanked: 133 times
That's the rear inverter to motor cable.
That price is very cheap for both cables. Was this listing for just one of the cables and did you get the right one?
- Has thanked: 134 times
- Been thanked: 337 times
Now you are truly on the path to put in Outlander motor and inverter
- Gregski
shhhh don't tell anyone but I am leaning that way for Conversion #3
- Gregski
I should get it today, it appears after it left UK it decided to tour California. I seem to live between a major receiving center and the post office distribution center on the other side of town, so they literally drive within 1 mile of my house from one place to the other in the morning, only to turn around and deliver it to my house later that evening
Sat, Mar 16 Out For Delivery Today West Sacramento, CA
Sat, Mar 16 Arrived at Facility West Sacramento, CA
Fri, Mar 15 Arrived at Facility Oakland, CA
Fri, Mar 15 Arrived at Facility Visalia, CA
Thu, Mar 14 We have your package Riverside, CA
Fri, Mar 8 Customs Cleared {UNKNOWN PLACE}, State 0000
Thu, Mar 7 Flight Touch Down LAX, CA 90045
- Gregski
Mitsubishi Outlander Charger Cables
- Gregski
Time to see if I can get charging working on the work bench
- ZombieVerter VCU
- Wiki: ZombieVerter VCU
- BMW 330e PHEV battery pack
- Wiki: BMW Hybrid Battery Pack
- Mitsubishi Outlander battery charger
- Gregski
so first, time to figure out the low voltage control wiring, and this guy seems to know what he's talking about
DIY EV Part 26 - Outlander PHEV OBC Charger Pt1 Three reasons Why I Failed Before.
Mr. Ali Bro
Mr. Ali Bro
The LV control connector is this one Sumitomo 6189-1092
And can be get here....
https://www.aliexpress.com/item/1005005 ... ry_from%3A
Or here
https://www.auto-click.co.uk/6189-1092
- Gregski
thank you so much, using only two colors for a dozen or so pins, my kinda people, lolarber333 wrote: ↑Mon Jun 10, 2024 3:54 pm The LV control connector is this one Sumitomo 6189-1092
- Has thanked: 380 times
- Been thanked: 1562 times
DIY then https://de.aliexpress.com/item/1005004366836123.html (I'm using that variant - less splicing)
Dont you smirk at me, i crimp my own pins
- Gregski
all set up for charging, fingers crossed
Mitsubishi Outlander Charger ZombieVerter VCU Working
- Has thanked: 76 times
- Been thanked: 3 times
looking good, so does the Zombie control the charge control then ?
- Gregski
the ZombieVerter VCU controls (talks to) the Mitsubishi Outlander on CAN Bus 2 so it uses these two pins on the connector
- Gregski
let's take a look at the ZombieVerter VCU software, and the settings we need to configure for the Outlander Charger
we start under Parameters (pronounced: "Settings") under the General Setup section
first we need to select Out_lander using the pulldown menu next to the chargemodes parameter
chargemodes: Out_lander
next we just need to verify (no need changing anything) that the ChargerCan pulldown menu is on it's default setting of CAN2
ChargerCan: CAN2
ChargerCan: CAN2
- Gregski
then we move on to the Charger Control section
so let's go over these one by one
- Has thanked: 370 times
- Been thanked: 222 times
Don't listen to anything that guy says. He's a MORON!!!
- Has thanked: 2 times
Can someone give a quick summary of the advantages of the Outlander charger vs others? I notices Damien also chose one..with combined with a leaf stack. TIA
- Has thanked: 209 times
- Been thanked: 572 times
Thanks for the super open ended question. Answer is what ever you need and can get worksdammogreen wrote: ↑Wed Feb 19, 2025 5:29 pm Can someone give a quick summary of the advantages of the Outlander charger vs others?
- Has thanked: 41 times
- Been thanked: 24 times
1. Cheap
2. Both a charger and a DCDC in a compact package
3. Supported by the Zombieverter
4. Good 2nd hand CAN reporting on charging voltage, current, temperature... To compare to your BMS reference or to use as its own control reference.Scrappyjoe wrote: ↑Wed Feb 19, 2025 8:04 pm 1. Cheap
5. Did i mention its quite cheap?
EDIT: Temp reporting is T[°C] + 40. So charger actually reports [hex] - 40 . Normaly primary and secondary temp are a bit different.
