Toyota/Lexus GS300h CVT
NOTE : This motor is as of yet untested in a real world application.
General overview :[3]
Description
The L210 is a continuously variable transmission (CVT) which can be found in the Lexus gs300h. It is very similar in design to the GS450h CVT. It contains two motor-generators - MG1 and MG2. When used as originally intended, MG1 is spun by the ICE, via a planetary gear system, and acts primarily as a generator. MG1 also acts as a starter motor for the ICE. MG2 is connected to the output shaft via a second planetary gear system to provide traction directly to the rear wheels.
Part Numbers
Gearbox
Tailshaft length 210mm
Weight 90kg
Oil pump
- Plug: 90980-12992[5] (approximately 20 euros)
- Terminal 1: 82998-24250
- Terminal 2: 82998-12790
- Terminal 3: 82998-24420[6]
Left hand side
Right hand side
- Ground strap
Resolvers
Sumitomo 6189-1240 8-WAY
Motor side connection
1 2 3 4
TMP1 CS SN RF
TMP2 CSG SNG RFG
5 6 7 8
Shift sensor
part number: 89451-30010
Output flange
ICE input shaft coupling
OEM numbers : Daihatsu 31250-14090; Lexus 31250-14010; Toyota 31250-12040;
Beta 3D printable Parts
https://toyota-club.net/files/faq/21-12-01_faq_hybrid_tr_en.htm
