Toyota Prius Gen3 Board
Prius Inverter
Control Board
As designed by Damien Maguire, the open source hardware for the control board can be purchased from his website:
Development History
Vendors
EVBMW Webshop
Support
Inverter Model Numbers
| G9200-47141 | Auris 2012, RHD Prius (RHD, unknown year, Gen3) |
| G9200-52010 | Yaris
Prius C |
LDO strengthening
Motor Temperature Sensor correction.
Boards currently have an error with the temperature sensor circuit. R14 is supposed to be in parallel with C11 to form the voltage divider. One workaround would be to put a 1k resistor from one of the pads to ground. this can be done externally if you'd rather not modify the board, put a 1k ohm resistor from MG2_STATOR_T2 to a ground pin. Then connector the temperature sensor from MG2_STATOR_T1 to MG2_STATOR_T2 as normal.
Wifi Module Correction
The capacitor may need increasing to 10uF deal with noise. The table below shows which boards need updating and which capacitor(s) to update.
Soldering The Breakout Board
Soldering the Main Board
Also easiest is to start with this connector, whilst the most complicated, starting with an unpopulated board allows easier access to it as the following connectors are largely around this one.
Depending on the kit and time you received it due to chip shortages, you might have IC12 and IC14 unpopulated and need to solder them on.
Each chip's 'pin one' has a small notch to indicate it and this matches the line and IC12 /IC14 silk screen on the board.
Again these are easier to get out of the way before the connectors are positioned.
And Conn8, again easy.
Ignore the 'Notch' on the board it needs to face outwards to the edge of the board, you'll also need to turn the sensor cables 180 deg to fit when installing the board.
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
- Write code to ESP8266
- Write filesystem to ESP8266
Programming Firmware
For Windows
A wifi network should be visible with the name "inverter" connect to it with password "inverter123"
Atmega328p Firmware
Be super careful never to program the Atmega while high voltage is applied and caps are not discharged. When cycling through the boot loader, it seems to do something strange that will blow up the otherwise bullet proof buck/boost converter! Also be aware that Arduino also cycles through the boot loader when closing the serial terminal!
Inverter Parameters
Parameters Details
First Run (PWM verify)
Navigate to the Web Interface
Change the parameter encmode to 'AB' as at the moment we don't have any sensors connected. Set udcmin to 0 to disable precharge.
Using a scope, look for a PWM signal on MG2 A/B/C Hi/Low on the 50 pin connector. R74 through R79 can be used as test points for the PWM signal - these are located next to the 50 pin connector as shown in the image below.
Stop the inverter
DC-DC Converter
D.Maguire
#include <Metro.h>
Metro timer_pwm=Metro(5);
void setup() {
Serial.begin(9600);//
PWMDuty=0;
void loop() {
HVHi = (analogRead(A1)*1.25);
void serialOUT()
if(timer_serial.check()){
Serial.print("Low Vbus = ");
Serial.print(HVLow);
Serial.print("Volts");
Serial.print(HVHi);
Serial.println(PWMDuty);
void updatePWM()
if(timer_pwm.check()){
if (HVLow<SetV) PWMDuty++;
if (HVLow>SetV) PWMDuty--;
if (PWMDuty<0) PWMDuty=0;
if (PWMDuty>250) PWMDuty=250;
analogWrite(10,PWMDuty);
if(HVHi<250)
// I/O-PINS
* SETUP *
void setup()
* LOOP *
void loop()
And Replace
12v Battery Connection
The HV battery connection is below, DO NOT directly connect the battery here. It needs to be connected via contactors and a pre-charge resistor. This connection point by-passes the buck/boost converter.
Motor Connection
Some versions of this inverter have the U-V-W labels for the three phase wires stamped into the case and some do not. These are shown below in case you have a version of the inverter without them and need to connect to a motor other than the originial prius transaxle.
Parallel MG1 and MG2 on a single motor
IDC Connector
Connections are as follows:
| 28 | HV_CON | ? |
| 31 | EVSE_PROX | |
| 32 | CONTROL_PILOT | |
Ampseal Socket & Plug
TE connectivity 776164-1 and 776163-1 are a matched pair[3].
| 34 | NOT USED | |
| 35 | NOT USED |
Connecting Resolver
Inverter as charger
Buck Mode Charging.
3D Printed Parts
More information on these parts can be found in this forum post https://openinverter.org/forum/viewtopic.php?t=836
3D Printed Part Locations
Frequently Asked Questions
Bill of Materials (Github)
