Tesla Model S GEN1 Charger
Charger Connectors
- AC (Input)
- DC (Output)
Wire size * |
Telsa
Wire Color * |
6 | FC CAN | AKA "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" | 20 AWG (0.5mm²) | RD-WH |
12 | "BMS_12V_in" | "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables charger?) | 18 AWG (0.75mm²) | RD-GY |
AC (Input) Connector
DC (Output) Connector
HVIL Connector "J5"
- J5 HVIL: Only the outside pins are in use. These are used to integrate the HVJB's Lid Reed Switch into the HVIL loop, and this is connected to the HVJB's Lid Reed Switch if the OBC is the only (single) or Master (dual) OBC.
- For Slave OBC, or all RAV4 EV, this connects to a short loopback harness instead. The loopback harness, Tesla 1101371-00-A, is included inside all Tesla Model S GEN1 Rear HVJB in a "parking" connector, when only a single OBC is provisioned.
- It is not known if the OBC performs PWM economizing. The Rear HVJB AC Bypass contactors are Tesla 1006871-00-A (TE Connectivity 2138957-2), but no datasheet can be found.
- The top row pins are 12v; the bottom row pins are NO (normally open) Auxiliary contacts.
- These connectors are not used in the Toyota RAV4 EV (possibly not used in MB B250e) as it is not provisioned for DCFC and does not have those contactors.
Common Issues
- Two 50A fuses protect the AC input legs: one fuse for Neutral, one for Hot/L1. These fuses are a common failure point. The cause of their failure is not known. Some units have had their fuses fail more than once. Typically, only one fails at a time. The fuses are "semiconductor fuses", special high-speed parts (opposite of "slow-blow") for use with sensitive electronics, and they sometimes have a hybrid diode-and-fuse symbol, though they have no diode function. The OEM fuse is Ferraz Shawmut 50A 500VAC fuse, part No. A50P50-4[16]. Some people have found that after replacing a single failed fuse, the other one will later fail; it is surmised that this is possibly a genuine instance of a fuse weakening over time/use, so the generic recommendation is to replace them both. Typical pricing is USD$50-100 each in 2023.
Important Considerations
Output Voltage Range
HEED DAMIEN'S WARNING:[17] |
Charger Dimensions:
- nnnmm x nnnmm x nnnmm
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
