Toyota/Lexus GS300h CVT
Revision as of 12:08, 9 March 2023 by Tom91 (talk | contribs) (Oil pump)
Forum board: [1][2]
General overview :[3]
Description
The L210 is a continuously variable transmission (CVT) which can be found in the Lexus gs300h. It is very similar in design to the GS450h CVT. It contains two motor-generators - MG1 and MG2. When used as originally intended, MG1 is spun by the ICE, via a planetary gear system, and acts primarily as a generator. MG1 also acts as a starter motor for the ICE. MG2 is connected to the output shaft via a second planetary gear system to provide traction directly to the rear wheels.
Part Numbers
Part numbers include 30920-30030. The CVT can be found in the Lexus GS300h, Lexus IS300h, and Toyota Crown Hybrid(G9200-30131). The matching inverter is part number G9200-30132, which is a Gen 3 inverter.
Tailshaft length 210mm
Weight 90kg
Oil pump
One key difference between the L210 (gs300h) and the L110 (gs450h) is that the L210 only has an internal oil pump. However, the internal oil pump is driven by both the ICE and/or the rotation of MG2. So, even when you lock the ICE input shaft to allow MG1 to provide traction, MG2 will still drive the oil pump whenever the car moves. Since there are no gears/speeds in this CVT (and hence no clutch packs, etc.), the oil is only required for cooling and lubricating the bearings.
  • Plug: 90980-129922[5] (approximately 20 euros)
  • Seals to plug unused connections: 90980-09871
  • Terminal 1: 82998-24250
  • Terminal 2: 82998-12790
  • Terminal 3: 82998-24420[6]
  • Alternative Source[7] for the Connectors on Aliexpress: [8] and [9]
Left hand side
Left hand side connections
Right hand side
Right hand side connections
  1. Input/output from/to oil cooler radiator
  3. Ground strap
Resolvers
Sumitomo 6189-1240 8-WAY
Motor side connection
1 2 3 4
TMP1 CS SN RF
TMP2 CSG SNG RFG
5 6 7 8
Shift sensor
part number: 89451-30010
Output flange
ICE input shaft coupling
