Tesla Model S/X Small Drive Unit ("SDU")
The Tesla SDU is used on Model S/X in both rear and front depending on the model.
Drop-in control board
Application Info
You may also set parameter „udcsw“ and „udcmin“ to 0 and start drive mode by pulsing 12V on Conn6.9. Then connect a pot between Conn6.4, Conn6.7 and Conn6.8 (wiper). This will also spin the motor AND enforce a speed limit. [Category:Gearbox]]
