ZombieVerter VCU
- STM32-CAR project
- Openinverter
- ISA library
- Throttle cal and mapping,
- Temp derating,
- BMS limits,
- for/rev/neutral control,
- Graphing and monitoring,
- Cruise control,
- Fuel gauge driver,
- etc
The current list of parts to be fitted:
CONN1
IC10 = MCP25625T
IC14 = TJA1020 OR MCP2004
IC19 = NCV7356
IC20 = TJA1055T
IC21, 22 = AD5160
IC27, 28, 29 = FAN3122
And the positions on the V1 board.
The enclosure kit links
- Enclosure Kit with Header, connector and pins :
- Prewired connector with 3M leads (limited colors which will not match standard wire colouring conventions) :
Video | Highlights |
<youtube>https://www.youtube.com/watch?v=geZuIbGHh30</youtube> |
00:33 Warning and suggestion to go watch cat videos instead |
<youtube>https://youtu.be/MUhs9j9R9Mg</youtube> |
00:34 Health warning and suggestion to go watch cat videos instead
Installation
Pin Out Diagram
- Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel. Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
Software
Various binaries can be found in the support thread, for example https://openinverter.org/forum/viewtopic.php?p=33379#p33379
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCU
In the file "stm32_can.cpp" @ starting at line 305 modify as follows :
./Stm32-vcu/libopeninv/src/
Software update
If you are unable to build your own, use the stm32_vcu.bin that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
If you are unable to build your own, use the stm32_vcu.hex that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
Initializing an ISA Shunt
Supported OEM Hardware
- chevy volt HV water heater
- BMW E46 CAN support
- BMW E39 CAN support
- BMW E65 CAN Support
