Toyota/Lexus GS300h CVT
NOTE : This motor is as of yet untested in a real world application.
General overview :[3]
Description
Part Numbers
Gearbox
Bellhousing diameter: 400mm
Length bellhousing face to drive flange face: 720mm
Diameter: main body 330mm front tapering to 250mm rear
Tailshaft length: 210mm
Weight: 90kg
3D Scan: https://grabcad.com/library/lexus-is-300h-inverter-1
Weight: 15.5kg
Oil pump
One key difference between the L210 (GS300h etc.) and the L110 (GS450h) is that the L210 only has an internal oil pump.
- Plug: 90980-12992[5] (approximately 20 euros)
- Terminal 1: 82998-24250
- Terminal 2: 82998-12790
- Terminal 3: 82998-24420[6]
+12V input needs to be fused at 5A, this is powered by the EV Relay controlled by the ZombieVerter
Left hand side
Right hand side
- Ground strap
Resolvers
Sumitomo 6189-1240 8-WAY
Motor side connection
1 2 3 4
TMP1 CS SN RF
TMP2 CSG SNG RFG
5 6 7 8
Shift sensor
part number: 89451-30010
Output flange
ICE input shaft coupling
OEM numbers : Daihatsu 31250-14090; Lexus 31250-14010; Toyota 31250-12040;
Beta 3D printable Parts
https://toyota-club.net/files/faq/21-12-01_faq_hybrid_tr_en.htm
