Mitsubishi Outlander DCDC OBC
Revision as of 20:19, 9 December 2025 by Bratitude (talk | contribs)
The charger has a 3.7k ohm resistance between the CAN H and CAN L pins.
* Length 370mm
* Width 270mm
* Height 150mm
* Weight 11.7kg
Internals:
Bottom Top
DC-DC Converter
The charger has an integrated DC-DC converter outputting a fixed voltage that seems to vary some between users. 14.5V is common value, but 14.35V and all the way up to 15V is reported. The converter requires battery voltage between 200V and 400V on the DC bus.
*at about 397v the DCDC appears to stop operating via the enable lines. Currently untested if it continues via can. [3]
The DCDC is capable of at least 1800W of power. At moderate power levels, the internal temperature is not increased much.
Signal Connector
Pinout for the Signal Connector [1][2][3][4][5]
Pin on 13-pin Connector DCDC Side Pin Number Pin on Internal Connector DCDC Side Color Color from Schematic Name Function
1 6 Orange NC Not Connected
2 5 Blank NC Not Connected
3 4 Blue NC Not Connected
4 3 Grey Violet-Green DC SW Enable DC/DC Converter
5 2 Light Blue Pink-Green CHIN Serial Protocol to EV Remote WiFi Module
6 1 Black Black-Blue CAN H CAN High
7 13 Green Grey Sense Sense for DC/DC Converter (via shared 7.5A fuse)
8 12 Yellow Light Green IGCT Main +12V Power Supply (via shared 7.5A fuse)
9 11 White Blue CP Control Pilot from Charge Port
10 10 Black Black GND Ground
11 9 Blank NC Not Connected
12 8 Purple Brown-Red / Yellow-Black CHOT Serial Protocol to EV Remote WiFi Module
13 7 Red Red-Blue CAN L CAN Low
Note: Although the above pin numbers, for the 13 pin external connector, match the Mitsubishi wiring diagram the numbers marked on the connector are reversed for each row. Pin 1 is CAN H (Black), pin 6 is NC (orange), pin 7 is CAN L (red ) and pin 13 Sense ( green ). IGCT +12V power should not be powered permanently, this will create problems for using the charger. Recommended to only have the Charger powered with Ignition on or charging.
Its not recommended to have permeant 12v supply to GND and IGCT as it will cause issues with the charger not functioning properly. recommended wiring with the zombiverter is as follows:
  • GND to ground
  • SENSE to permeant 12v+
  • IGCT to switch 12v+ via a relay controlled by an zombie output pin set to "HVactive"
  • DC SW to zombie controlled IGN relay
this ensures the DCDC only starts drawing HV after precharge is complete, and powers down the OBC when the HV system is off. the zombie must take care of the proximity pilot detection in order imitate charge mode, which will turn on the HV, outlander dcdc, and start sending the correct CAN messages for charging.
External Connector
Internal Connector
Empty Connector in Socket
In case the Charger doesn't come with the signal pigtail (which it usually does), the internal signal connector is from the Hirose GT8E series[6], specifically the Hirose GT8E-12DS-HU[7] with Hirose GT8E-2022SCF[8] pins.
The External to Internal wiring harness is as follows:
Internal Connector (Black) External Connector (Grey)
Pin Wire Colour Pin Function (If Known)
1 grey 4 DC SW - Enable DC/DC Converter
2 blue 3 NC
3 black 6 CAN H -CAN High
4 black 10 GND – Ground
5 yellow 8 IGCT – Main +12V Power Supply (via shared 7.5A fuse)
6 green 7 Sense - Sense for DC/DC Converter (via shared 7.5A fuse)
7 light blue 5 CHIN - Serial Protocol to EV Remote WiFi Module
8 NC 11 NC
9 orange 1 NC
10 red 13 CAN L – CAN Low
11 purple 12 CHOT – Serial Protocol to EV Remote WiFi Module
12 white 9 CP – Control Pilot from Charge Port
AC Power Connector
Mitsubishi "MUC000691" cap
The AC power connector is Yazaki 7283-7350-30 / Toyota 90980-11413[9].
+12V DC Connector
The thread size of the +12V stud of the DC/DC converter is M8. The Mitsubishi part number for the correct cap is "MUC000691".
Charge Control
The OBC is capable of delivering 12A DC. Dependent on your system voltage, the power output may be limited below 3.7 kW. For example, for a 250V system, the power output is only 12*250 = 3kW.
CANBus Messages
Outlander Charger DBC File
https://github.com/haand22/Mitsubishi_Outlander_PHEV.git
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The requested current should be limited to 12A, going above this results in strange current delivery. If 13A is requested, charging does not even start.
Charger will only start charging if EVSE CP is connected and requested current is below EVSE limit.
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v)
- B5 = Temperature 2		(starts at -40degC, +1degC/bit)
- B6 = Temperature 3		(starts at -40degC, +1degC/bit)
- B7 = Statusbyte 		(0x20=standby, 0x21=error, 0x22=in operation)
-  - bit0(LSB) = Error
-  - bit1	= In Operation
-  - bit3      =
-  - bit4      =
-  - bit5      = Ready
-  - bit6	=
-  - bit7(MSB) =
0x389
- B6 = AC Supply Current x 10
- B7 = DC side current x 10 (should equal commanded current)
0x38A
- B0 = temp x 2?
- B1 = temp x 2?
Parallel charger control:
Charger voltage control:
CAN_FRAME incoming;
if (Can0.available() > 0) {
    Can0.read(incoming);
    if (incoming.id == 0x389) {
        voltage = incoming.data.bytes[0];
        Ctemp = incoming.data.bytes[4];
    if (incoming.id == 0x377){
        aux1 = incoming.data.bytes[0];
        aux2 = incoming.data.bytes[1];
        auxvoltage = ((aux1 * 256) + aux2); //recalculate two bit voltage value
void sendCANframeA() {
	outframe.id = 0x286; // Set our transmission address ID
	outframe.rtr=1; //No request
	outframe.data.bytes[0]=0x28;
	if(voltage < 193) { // if Charger senses less than 386V
		outframe.data.bytes[2]=0x1E;
	else {  //any other case
		outframe.data.bytes[2]=0x00;
	outframe.data.bytes[4]=0x00;
	outframe.data.bytes[5]=0x00;
	outframe.data.bytes[6]=0x0A;
	outframe.data.bytes[7]=0x00;
DCDC aux voltage control
if (auxvoltage < 1200) { // if aux voltage is low and DCDC is off
    auxState = true; // set the flag to true
    elapsedtime = millis();
DCDCauxcharge();
void DCDCauxcharge() {
    if ((auxState == true) && (digitalRead(Enable_pin) == LOW)) { // auxvoltage went below 12.2V
        digitalWrite(DCDC_active, HIGH);
        if (millis() - elapsedtime >= ontime) { // if aux voltage is low and for 5min
            auxState = false;
    else { // if auxvoltage is OK
        auxState = false; // turn off DCDC_active relay
