Mitsubishi Outlander DCDC OBC
The charger has a 3.7k ohm resistance between the CAN H and CAN L pins.
* Length 370mm
* Width 270mm
* Height 150mm
Internals:
Bottom Top
DC-DC Converter
*at about 397v the dcdc appears to stop operating via the enable lines. currently untested if it continues via can. [3]
Signal Connector
Pinout for the Signal Connector [1][2][3][4][5]
Pin on 13-pin Connector DCDC Side Pin Number Pin on Internal Connector DCDC Side Color Color from Schematic Name Function
1 6 Orange NC Not Connected
2 5 Blank NC Not Connected
3 4 Blue NC Not Connected
4 3 Grey Violet-Green DC SW Enable DC/DC Converter
5 2 Light Blue Pink-Green CHIN Serial Protocol to EV Remote WiFi Module
6 1 Black Black-Blue CAN H CAN High
7 13 Green Grey Sense Sense for DC/DC Converter (via shared 7.5A fuse)
8 12 Yellow Light Green IGCT Main +12V Power Supply (via shared 7.5A fuse)
9 11 White Blue CP Control Pilot from Charge Port
10 10 Black Black GND Ground
11 9 Blank NC Not Connected
12 8 Purple Brown-Red / Yellow-Black CHOT Serial Protocol to EV Remote WiFi Module
13 7 Red Red-Blue CAN L CAN Low
Note: Although the above pin numbers, for the 13 pin external connector, match the Mitsubishi wiring diagram the numbers marked on the connector are reversed for each row. Pin 1 is CAN H (Black), pin 6 is NC (orange), pin 7 is CAN L (red ) and pin 13 Sense ( green ).
External Connector
Internal Connector
Empty Connector in Socket
In case the Charger doesn't come with the signal pigtail (which it usually does), the internal signal connector is from the Hirose GT8E series[6], specifically the Hirose GT8E-12DS-HU[7] with Hirose GT8E-2022SCF[8] pins.
The External to Internal wiring harness is as follows:
Internal Connector (Black) External Connector (Grey)
Pin Wire Colour Pin Function (If Known)
1 grey 4 DC SW - Enable DC/DC Converter
2 blue 3 NC
3 black 6 CAN H -CAN High
4 black 10 GND – Ground
5 yellow 8 IGCT – Main +12V Power Supply (via shared 7.5A fuse)
6 green 7 Sense - Sense for DC/DC Converter (via shared 7.5A fuse)
7 light blue 5 CHIN - Serial Protocol to EV Remote WiFi Module
8 NC 11 NC
9 orange 1 NC
10 red 13 CAN L – CAN Low
11 purple 12 CHOT – Serial Protocol to EV Remote WiFi Module
12 white 9 CP – Control Pilot from Charge Port
AC Power Connector
Mitsubishi "MUC000691" cap
The AC power connector is Yazaki 7283-7350-30 / Toyota 90980-11413[9].
+12V DC Connector
The thread size of the +12V stud of the DC/DC converter is M8. The Mitsubishi part number for the correct cap is "MUC000691".
Charge Control
CANBus Messages
Outlander Charger DBC File
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The charger reads this value only once. To update it, you have to first power cycle the 12V line "Pin 8 IGCT main power to charger". The requested current should be limited to 12A, going above this results in strange current delivery.
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v)
- B5 = Temperature 2		(starts at -40degC, +1degC/bit)
- B6 = Temperature 3		(starts at -40degC, +1degC/bit)
- B7 = Statusbyte 		(h20=standby, h21=error, h22=in operation)
-  - bit0(LSB) = Error
-  - bit1	= In Operation
-  - bit3      =
-  - bit4      =
-  - bit5      = Ready
-  - bit6	=
-  - bit7(MSB) =
0x389
- B6 = Charger Supply Current x 10
0x38A
- B0 = temp x 2?
- B1 = temp x 2?
Parallel charger control:
Charger voltage control:
CAN_FRAME incoming;
if (Can0.available() > 0) {
    Can0.read(incoming);
    if (incoming.id == 0x389) {
        voltage = incoming.data.bytes[0];
        Ctemp = incoming.data.bytes[4];
    if (incoming.id == 0x377){
        aux1 = incoming.data.bytes[0];
        aux2 = incoming.data.bytes[1];
        auxvoltage = ((aux1 * 256) + aux2); //recalculate two bit voltage value
void sendCANframeA() {
	outframe.id = 0x286; // Set our transmission address ID
	outframe.rtr=1; //No request
	outframe.data.bytes[0]=0x28;
	if(voltage < 193) { // if Charger senses less than 386V
		outframe.data.bytes[2]=0x1E;
	else {  //any other case
		outframe.data.bytes[2]=0x00;
	outframe.data.bytes[4]=0x00;
	outframe.data.bytes[5]=0x00;
	outframe.data.bytes[6]=0x0A;
	outframe.data.bytes[7]=0x00;
DCDC aux voltage control
if (auxvoltage < 1200) { // if aux voltage is low and DCDC is off
    auxState = true; // set the flag to true
    elapsedtime = millis();
DCDCauxcharge();
void DCDCauxcharge() {
    if ((auxState == true) && (digitalRead(Enable_pin) == LOW)) { // auxvoltage went below 12.2V
        digitalWrite(DCDC_active, HIGH);
        if (millis() - elapsedtime >= ontime) { // if aux voltage is low and for 5min
            auxState = false;
    else { // if auxvoltage is OK
        auxState = false; // turn off DCDC_active relay
