Mitsubishi Outlander DCDC OBC
* Length 370mm * Width 270mm * Height 150mm
DC-DC Converter
*at about 397v the dcdc appears to stop operating via the enable lines. currently untested if it continues via can. [3]
Pinout as as follows:
- Pin 1 (Orange) NC on outlander
- Pin 2 NC on outlander
- Pin 3 (Blue) NC on outlander
- Pin 4 DC SW enables the DC:DC converter
- Pin 5 CHIN (Serial protocol to EV Remote wifi module)
- Pin 6 CAN H (Black)
- Pin 7 Sense line for DC to DC converter
- Pin 8 IGCT main power to charger
- Pin 9 Control Pilot from charging cable
- Pin 10 GND
- Pin 11 NC
- Pin 12 CHOT (Serial protocol to EV Remote wifi module)
- Pin 13 CAN L (Red)
Note: Although the above pin numbers match the Mitsubishi wiring diagram the numbers marked on the connectors are reversed for each row. Pin 1 is CAN H (Black), pin 6 is NC (orange), pin 7 is CAN L (red ) and pin 13 Sense ( green ).
The AC power connector is Yazaki 7283-7350-30 / Toyota 90980-11413. https://www.auto-click.co.uk/7283-7350-30?search=90980-11413
Charge Control
CANBus Messages
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The charger reads this value only once. To update it, you have to first power cycle the 12V line "Pin 8 IGCT main power to charger". The requested current should be limited to 12A, going above this results in strange current delivery.
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v) - Byte 2 = Current in amps x 10
- B0+B1 = 12V Battery voltage (h04DC=12,45V -> 0,01V/bit) - B2+B3 = 12V Supply current (H53=8,3A -> 0,1A/bit) - B4 = Temperature 1 (starts at -40degC, +1degC/bit) - B5 = Temperature 2 (starts at -40degC, +1degC/bit) - B6 = Temperature 3 (starts at -40degC, +1degC/bit) - B7 = Statusbyte (h20=standby, h21=error, h22=in operation) - - bit0(LSB) = Error - - bit1 = In Operation - - bit3 = - - bit4 = - - bit5 = Ready - - bit6 = - - bit7(MSB) =
0x389
- B0 = Battery Voltage (as seen by the charger), needs to be scaled x 2, so can represent up to 255*2V; used to monitor battery during charge - B1 = Charger supply voltage, no scaling needed - B6 = Charger Supply Current x 10
0x38A
Parallel charger control:
Charger voltage control:
CAN_FRAME incoming; if (Can0.available() > 0) { Can0.read(incoming); if (incoming.id == 0x389) { voltage = incoming.data.bytes[0]; Ctemp = incoming.data.bytes[4]; } if (incoming.id == 0x377){ aux1 = incoming.data.bytes[0]; aux2 = incoming.data.bytes[1]; auxvoltage = ((aux1 * 256) + aux2); //recalculate two bit voltage value } }
void sendCANframeA() { outframe.id = 0x286; // Set our transmission address ID outframe.length = 8; // Data payload 8 bytes outframe.extended = 0; // Extended addresses - 0=11-bit 1=29bit outframe.rtr=1; //No request outframe.data.bytes[0]=0x28; outframe.data.bytes[1]=0x0F; // 0F3C=3900, 0DDE=3550, 0,1V/bit if(voltage < 193) { // if Charger senses less than 386V outframe.data.bytes[2]=0x78; // 78=120 12A, 50=80 8A, 32=50 5A, 1E=30, 3A 14=20 2A at 0,1A/bit } else if(voltage <= 194) { // if Charger senses less than or equal 388V outframe.data.bytes[2]=0x1E; } else { //any other case outframe.data.bytes[2]=0x00; } outframe.data.bytes[3]=0x37; // why 37? outframe.data.bytes[4]=0x00; outframe.data.bytes[5]=0x00; outframe.data.bytes[6]=0x0A; outframe.data.bytes[7]=0x00; if(debug) {printFrame(&outframe,1); } //If the debug variable is set, show our transmitted frame if(myVars.CANport==0) Can0.sendFrame(outframe); //Mail it else Can1.sendFrame(outframe); }
DCDC aux voltage control
if (auxvoltage < 1200) { // if aux voltage is low and DCDC is off auxState = true; // set the flag to true elapsedtime = millis(); } DCDCauxcharge();
void DCDCauxcharge() { if ((auxState == true) && (digitalRead(Enable_pin) == LOW)) { // auxvoltage went below 12.2V digitalWrite(DCDC_active, HIGH); if (millis() - elapsedtime >= ontime) { // if aux voltage is low and for 5min digitalWrite(DCDC_active,LOW); // turn off DCDC_active relay elapsedtime = millis(); auxState = false; } } else { // if auxvoltage is OK auxState = false; // turn off DCDC_active relay } }
