ZombieVerter VCU
Revision as of 16:16, 22 November 2021 by Bassmobile (talk | contribs) (Software: adding info on the GigaDevices GD32F107)
What we have as of now is the openinverter wrapper with things like :
  • Throttle cal and mapping,
  • Precharge and contactor control,
  • Temp derating,
  • BMS limits,
  • for/rev/neutral control,
  • Graphing and monitoring,
  • Firmware updates via the web interface,
  • Cruise control,
  • Fuel gauge driver,
  • etc
The current list of parts to be fitted:
CONN1
IC10 = MCP25625T
IC14 = TJA1020 OR MCP2004
IC19 = NCV7356
IC20 = TJA1055T
IC21, 22 = AD5160
IC27, 28, 29 = FAN3122
And the positions on the V1 board.
The enclosure kit links
Enclosure Kit with Header, connector and pins :
Prewired connector with 3M leads :
Installation
Pin Out Diagram
VCU pinout diagram
List of connections to system components (GS450 application)
Software
GD variant:
Status as of November 2021
ST Variant:
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel. Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
If it does not show up, check for errors and check that throtmax is not set to zero!
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
Software update
If you are unable to build your own, use the stm32_vcu.bin that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
If you are unable to build your own, use the stm32_vcu.hex that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
Initializing an ISA Shunt
Supported OEM Hardware
  • Nissan Leaf Gen1/2/3 Inverter/ motor
  • nissan leaf gen 2 drive stack (inverter, dcdc, charger) gen 3 coming soon
