Toyota/Lexus GS300h CVT
Revision as of 15:21, 15 January 2026 by Marcexec (talk | contribs) (Description)
Forum board: [1][2]
General overview :[3]
Description
Part Numbers
Gearbox
Bellhousing diameter: 400mm
Length bellhousing face to drive flange face: 720mm
Diameter: main body 330mm front tapering to 250mm rear
Tailshaft length: 210mm
Weight: 90kg
3D Scan: https://grabcad.com/library/lexus-is-300h-inverter-1
Weight: 15.5kg
Oil pump
One key difference between the L210 (GS300h etc.) and the L110 (GS450h) is that the L210 only has an internal oil pump.
  • Plug: 90980-12992[5] (approximately 20 euros)
  • Seals to plug unused connections: 90980-09871
  • Terminal 1: 82998-24250
  • Terminal 2: 82998-12790
  • Terminal 3: 82998-24420[6]
  • Alternative Source[7] for the Connectors on Aliexpress: [8] and [9]
+12V input needs to be fused at 5A, this is powered by the EV Relay controlled by the ZombieVerter
Left hand side
Left hand side connections
Right hand side
Right hand side connections
  1. Input/output from/to oil cooler radiator
  3. Ground strap
Resolvers
Sumitomo 6189-1240 8-WAY
Motor side connection
1 2 3 4
TMP1 CS SN RF
TMP2 CSG SNG RFG
5 6 7 8
Shift sensor
part number: 89451-30010
Output flange
ICE input shaft coupling
Beta 3D printable Parts
https://toyota-club.net/files/faq/21-12-01_faq_hybrid_tr_en.htm
